12-24-2014, 12:45 PM | #1 |
Drives: 2014 Subaru Forester Turbo Join Date: Aug 2013
Stock tune after cam install help please
Can I drive from my garage to my tuner? He is about 3 hours away. It is a Brian Tooley stage 2 cam. Headers will be installed at the same time. Thank you
12-24-2014, 02:22 PM | #2 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
Not a good idea at all. You will see after the cam gets installed it will idle and that's about it. It will die everyone you push the clutch in
12-25-2014, 09:36 PM | #3 |
Seriously???
12-25-2014, 09:57 PM | #4 |
xquest91x
Drives: 2012 45th Anniversary 2SS/RS Join Date: Mar 2013
Not 100% true....it will idle and want to die on you but if you give it enough gas you can get it up and going no problem, only thing you don't wanna do is drive it rough. Meaning don't start driving and shifting at high rpm, shift at 2-3k and you will be fine. My buddy and me drove from yuma to Phoenix ( 3hrs roughly) and had no issues at all but you run through gas fast because it is not tuned. Just giving you my personal situation ($0.02)... If you can tow it, go for it but you don't have too.
2012 45th Camaro 2SS/RS LS3
Driver Mod: Stage 5 Full Bolt-ons + Tune •418RWHP/420RWTQ• H/C + Bolt-ons + Tune •485RWHP/435RWTQ• Full BMR Stage 2&3 Suspension 3.91 1LE Gear Diff Swap MGW Short Throw Shifter |
12-26-2014, 07:51 AM | #5 |
Drives: 1999 Trans Am Join Date: Jul 2009
You can do it. Might be a bitch at times but can be driven.
12-26-2014, 01:12 PM | #6 |
Thanks guys. didn't want to lean out the motor. I will be driving it VERY gently
12-27-2014, 02:44 PM | #7 |
Its been done tons of times. Just depends on your skill of keeping an engine running that doesn't want to run lol. The more aggressive the cam the worse it will be.
12-31-2014, 01:16 PM | #8 |
Too much is never enough!
if you have HPT, you can have your tuner send you a start up file to get you there with less aggravation.
01-04-2015, 05:09 PM | #9 |
Fight Crime, Drive Armed
Drives: '14 2SS Yelo Maro, HD collection Join Date: Jun 2013
Pay for the gas and get a buddy with a truck and a trailer.
Bring back Sunoco 260 to the local station. Some folks STILL drive L-88s and need the good gas.
01-04-2015, 05:36 PM | #10 |
Drives: rumble bee,2SS 6sp Join Date: May 2009
drive it... i drove for 3 weeks (truck broke before i got a tune in the camaro) just dont go full throttle it will crush fuel like said before be lucky at 10 mpg city.
blk 2ss 6spd with sunroof.
intake,tsp cam,full exhaust,pcmforless tune,trailing arms,toe rods. hopeing for 11.9 because my g/f said she will take the cam and the suspension back if not. |
01-05-2015, 09:13 AM | #11 |
Very good advice!
01-06-2015, 10:18 PM | #12 |
Drives: ‘13 1LE Join Date: Jul 2013
.....and bad for your cats the longer you drive it like that, unless you think about these things in advance, and go cat-less for that bit longer .
