01-08-2015, 10:39 PM | #1 |
Drives: 2014 chevy camaro 1ss rs auto Join Date: Oct 2013
tuner near miami, Fl.
Whats up all,
So im really close to buying my long tubes and i want to tune the car after i instal since i have all the basic bolt ons and minor porting. Ive heard great things about florida speed and power but they are 250 miles from where I live. Any know of a good place thats a little closer or should i just make the trip up there? I live in the kendal area miami fl. 33175 Also is driving the car after the install safe or should i have it installed there? In case it matters i have a cold air intake, throttle body ported and modded by bo, ported intake manifold and 2.5 inch catback exhaust. Looking to purchase either some kooks, tsp, or stainless power 1 7/8 headers with off road connection. I have a 2014 ss/rs l99. Thanks in advance! |
01-09-2015, 12:44 AM | #2 |
Drives: 2013 ZL1 ADM 750 Join Date: Dec 2014
That shop has a great reputation for its work. Don't hesitate to take it there.
I sent mine to Texas on reputation alone. You won't be disappointed. |
01-09-2015, 01:27 AM | #3 |
You can get a trifecta mail tune they are one of the cheapest and they do data logging. I switched to HP tuners tho. I have a guy local for me that tunes my car.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/ |
01-09-2015, 02:29 AM | #4 |
Drives: 2011 SS/RS LS3 Join Date: Oct 2010
I've had great luck with Jeremy Formato (owns Fasterproms). He normally travels to Miami or Davie every month or so. He can work wonders with the shift settings of your auto. He normally posts schedules in the Fl. section on ls1tech.
01-09-2015, 06:31 AM | #5 |
Used Matt @Florida Speed for the tune on my 2014 1LS. Takes pride in what he does. You can't go wrong with him, plus if you have ideas on future mods , you can run them by him.
01-09-2015, 06:40 AM | #6 |
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM Join Date: Oct 2010
You have Redline Motorsports in Pompano Beach just north of you. They are the industry standard.
01-09-2015, 07:32 AM | #7 |
Drives: 2013 2SS/RS convertable Join Date: Aug 2014
Also Lashway motorsports, they did my headers + tune for a good price and I loved the work they did enough that I'm having them do another $8k worth of work later this month.
2013 2SS/RS Vert
Mods list to long to fit in sig now lol Check build thread http://www.camaro5.com/forums/showthread.php?t=377507 |
01-09-2015, 03:52 PM | #8 |
Thanks for the replies everyone! Ill give all these guys a close consideration. Ill check in after the jobs done and let everyone know how it turned out.
01-09-2015, 03:57 PM | #9 |
Treasure Coast Camaro 5
Yes for local or close Redline or Lashaway.
01-17-2015, 04:31 AM | #10 |
Too much is never enough!
I would also recommend you go with Matt @ FSP, I had him remote tune my car before I sent it to him for the turbo kit, he had it almost perfect before I got to the dyno. I was out of state at the time, I pulled on the dyno and did about 5 runs and that was it. Custom dyno tune from 1100 miles away. You'll be hard pressed to find a bad comment about him. Top notch group of guys. If you call the shop and don't get him, try e-mailing him, he stays busy.
01-17-2015, 05:53 AM | #11 |
In Delray . KraftWorks. Hes on Facebook. Everybody mentioned is GOOD. U will find somebody that doesn't like 1 of them also.
01-17-2015, 07:28 AM | #12 |
Drives: Nsrt & Camaro SS Join Date: Nov 2014
I have a guy pm me, yrs you'll be fine driving around after mod installed
01-20-2015, 11:36 AM | #13 |
Drives: C6 Corvette Join Date: Sep 2013
If you are going to make the 250mi trip this way I would recommend Phil with TampaTuning. Most detailed accurate work I've ever seen done.
2008 C6 m6. Carbon creations front/rear carbon fiber wodebody fenders. Carbon fiber hood carbon fiber roof hoop carbon fiber zr1 extreme spoiler. NW 102mm tb. Ported intake manifold. Cometic .040 head gaskets. LG motorsports G6x3 cam. DSX flex fuel sensor. AEM methanol kit. Z06 brakes. Ebiach sway bars. ZR1 rep wheels and Nitto Invo tires. Monster stage 3 twin disc clutch. MGW short shifter. Corbeau race seats. Gforce race harnesses. SLP loudmouth 2 mufflers. Carbon fiber exhaust tips. RPM stage 4 transmission and Stage 3 rear diff. 3.73 gears. Vararam cai. Kooks 1 7/8 headers and x-pipe.
01-20-2015, 11:38 AM | #14 |
Drives: 2013 2ss hot wheels camaro vert Join Date: Jun 2013
highly recommend phil...tampa tuning...
SLP SUPERCHARGER,3.6 PULLEY..HEADERS,HIGH FLOW CATS,BORLA S CATBACK,CAI INTAKE,ZL1 FUEL PUMP,ELITE CATCH CAN,TUNED BY PHIL AT TAMPA TUNING
