Old 03-14-2018, 06:36 AM   #1
COBARO1
Drives: 2011 camaro SS
QTP Cutout Rear Exhaust Piping
QTP Cutout Rear Exhaust Piping for sale. $165 shipped. This is for after the axle piping only. THIS DOES NOT INCLUDE THE CUTOUTS. This was my mock up system for the rear exhaust cutouts I hade made by SPINTECH. They are painted with black high temp paint and work perfectly.
COBARO1 is offline   Reply With Quote
Old 03-14-2018, 07:58 PM   #2
rwhxk3
S1N1STR
rwhxk3's Avatar
Drives: 2013 Camaro 2SS
Those are sweet. Did you have it rigged up to the stock exhaust?
Sent from my iPhone using Tapatalk Pro
rwhxk3 is offline   Reply With Quote
Old 03-15-2018, 04:29 AM   #3
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
Having cutouts behind the rear axle myself, I gotta say this is the way to go. All the noise you could want, but none of the fumes and reverberation right under the cabin like you get with a lot of more "traditional" installs that are right under the center of the car. Nice little setup here - just buy yourself a set of valves and install.
2011 2SS SGM - CAI, PTB, Rod-Mod and ported intake, GPI SS3 cam, AR LTs 1.875", X-pipe, high flow cats, cutouts. 25% UPD, 169*F stat, Ideal Garage clutch master and reservoir, Tilton 6100 HRB, Mcleod RXT, Yukon 4.11 gears, TruTrac Differential, LPW Diff Cover, BMR Pro diff bushings, Pegasus Solid rear sub-frame bushings. 497rwhp. 11.67@119 2+ton raceweight.
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 03-15-2018, 05:45 AM   #4
COBARO1
Set up for stock 2.5" SS exhaust. You should use them if you are running headers and want to open up the exhaust note. Mounted in the rear decreases cabin noise considerably, removes heat from under the seat and system wiring is not exposed to heat which negatively affects a remote control system and the actuators. When they were under the seat I had to wrap actuating system with heat protectors which are no longer required. Used with locking bolts these do not leak by at all behind the axle and I moved them because of all of the above reasons. I left a portion of stock exhaust so you would know where to cut out your exhaust and weld in this system. Any exhaust shop should be able to completely mount this system in under 2 hours including setting up wiring controls. already being pre-made eliminates the trial and error of installation.
Old 03-15-2018, 09:49 AM   #5
Shanelique
Shanelique's Avatar
Drives: 2010 camaro ss
I want these. Message me please.
Shanelique is offline   Reply With Quote
Old 03-20-2018, 03:06 PM   #6
COBARO1
Exhaust cutout piping
SOLD
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
