#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > Transmissions
Old 04-21-2018, 08:27 AM   #1
parish8
Drives: 17 SS a8
A8 exploded
Went to the track tonight, opening night. I was maybe the 10th car in line. During the burn out the transmission completely exploded. Parts and oil everywhere. It was even on fire for a few seconds with the turbos getting bathed in trans fluid. I think the only thing holding the bellhousing to the tail is the steel oil pan. No idea why this happened, I have made a pile of changes from last year.
Since last year new converter, frenshed up trans, drop in pistons and rods, tuning.
I can tell you my burn out was a bit more aggressive than I meant it to be. The track was slick and the wheels spun much easier than I anticipated. I did bumb the limiter a little before it blew up. Also I did my burn out in drive. I am now being told that is not ideal on the a8 for some reason and to just put it in 2 manual for the burn out.
There will be some collateral damage. Turbo blankets are crispy, at lead one transmission line is kinked, I am sure there is some wiring damage. I will be pretty sad if the motor is hurt. Hell maybe the motor broke first and somehow took out the trans. I will post up whatever I find and hope to get it out of the car today.
dropped a valve in the 6.2. now running a drop in rods and piston 5.3
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472
parish8 is offline   Reply With Quote
Old 04-21-2018, 08:36 AM   #2
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
Ouch!! Sorry to hear that and hope it was just the transmission that was damaged.
Mark114 is offline   Reply With Quote
Old 04-21-2018, 09:33 AM   #3
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
Wasn't your transmission built?
danhr is offline   Reply With Quote
Old 04-21-2018, 09:49 AM   #4
parish8
Drives: 17 SS a8
Yep. My understanding of that right now is fresh stock clutches. Add a clutch or two in one or two of the packs and valve body mods. I am not a transmission guy. Right now upgrades to the a8 is limited.
Old 04-21-2018, 04:42 PM   #5
soloknight6
SoCal HT5! SD
soloknight6's Avatar
Drives: 2016 red hot 2ss M6
time for a ten speed?
soloknight6 is offline   Reply With Quote
Old 04-21-2018, 04:47 PM   #6
parish8
Drives: 17 SS a8
I am not sure if anyone has that swap sorted out. Also I don’t know if the 10 speed is any stronger.
Old 04-21-2018, 10:31 PM   #7
parish8
Drives: 17 SS a8
Old 04-22-2018, 06:36 AM   #8
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
Some people overstate what happened with words like "exploded". In your case I think exploded might not be descriptive enough! That is an amazing and scary amount of damage. Good luck with the repairs and sorting out what happened.
2010 Camaro 2SS Cam/Headers/CAI/3.91 gears
476 rwhp/440 rwtq (sold)
SSDan is offline   Reply With Quote
Old 04-22-2018, 07:27 AM   #9
CruzinQueen
CruzinQueen's Avatar
Drives: 2017 1LT RS Convertible V6 A8
WOW. No joke. That thing is a mess.
2017 Camaro 1LT RS V6 A8 Convertible - Silver Ice/Black Cloth, K&N CAI, MRT v. 2 Axle Back, Redline-style Badges and Wheel Hashes, American Authority Grille & a Whole Lot of Attitude
2019 GMC Terrain SLE 1.5T - Blue Steel Metallic/Black Cloth "Soccer Mom Spec"
CruzinQueen is offline   Reply With Quote
Old 04-22-2018, 01:24 PM   #10
CruzySS
CruzySS's Avatar
Drives: 2016 Camaro 2ss
Holy crap!
I classify that as an explosion. Sorry bud that looks expensive.
CruzySS is offline   Reply With Quote
Old 04-22-2018, 01:31 PM   #11
danhr
BAMF SS
danhr's Avatar
At the power levels you are at, I'm curious if it was from case deflection or something from the inside.
Old 04-22-2018, 02:06 PM   #12
Wierd Harold
Drives: 2017 2lt rs
Agree,I can't believe how thin that case is.
Wierd Harold is offline   Reply With Quote
Old 04-22-2018, 02:14 PM   #13
Snowblind
Snowblind's Avatar
Drives: '16 2SS / '05 SRT10 Ram / '65 bu
That is frustrating, sorry to see that.
Level it, put a glass top on it and make it a coffee table.The center of attention and a conversation piece in your family room.
H/C SBE 9.80@140 powered by Texas Speed
Snowblind is offline   Reply With Quote
Old 04-22-2018, 04:02 PM   #14
yotaman96
yotaman96's Avatar
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6
Dang
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2002 Trans Am
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
