04-23-2011, 01:24 AM | #1 | |
Camaro➎ moderator
Help with recovering lost media and documents.
So, the computer was put through a system restore and now all the pictures, music, documents, etc... are gone.
I tried this Quote:
Any help? Or is there an easier way to do this? |
04-23-2011, 01:41 AM | #2 |
Moderator.ca
I'm no expert, but it sounds like that method is for 'misplaced' files and folders. You know where they are, but the computer doesn't. But when files disappear via a restore, they usually just go 'poof' and aren't heard from again.
I take it you don't have a backup of any sort?
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
04-23-2011, 01:55 AM | #3 |
Nightmare
Drives: Your mom crazy in bed Join Date: Mar 2011
If you did a system restore, it means you most likely set your system back to factory specs. Unfortunately, that means pretty much everything has been "soft formatted". Basically, it wipes out all the locations/history of said files...
There's software out there that will let you recover the files...but if you have the option, the best route is to use another PC to do this.... Is it a desktop/laptop?
04-23-2011, 02:14 AM | #4 | |
Nightmare
On the right hand side of the screen, you will see the following: Name: basically a description of the file Type: basically what the folder does Data: Where the file is located What they are asking you to do, is look at this data and see if you see anything that doesn't match. Such as seeing one say "john" instead of "data". If so, they want you to restore the file to it's default option. Unfortunately, the registry is a pain in the ass to screw with if you don't know it, and even doing all this doesn't guarantee your files back... I'm including a copy of my registry window (windows 7 64-bit).
04-23-2011, 02:09 PM | #5 |
Camaro➎ moderator
I figured it out.
Although the pictures and music don't show up anywhere on the computer, they still show up on windows media player. So, I'm just extracting them with a flash drive before the computer takes a dump on itself. |
04-23-2011, 08:43 PM | #6 |
Nightmare
Well, if you want more help, let me know...it's what I do for a living..
