10-05-2019, 06:29 PM | #1 |
Drives: 2015 Camaro SS/RS 1LE Join Date: Jun 2016
DSE suspension
If I install the Detroit Speed rear cradle mount solid aluminum bushings, will the noise, harshness and vibration be absolutley annoying ?
My 1LE is only driven on the street, no track time. While I'm at it, will the DSE lowering springs front & rear work with the Bilstein B6 shocks ? Thanks in advance ! |
10-05-2019, 07:13 PM | #2 |
It depends on how much noise is already present - it will be amplified
Bils B6 with DSE springs should be an excellent combination. (haven't done that myself so, grain of salt) I've run bils with eibach, bils with H&R, and bilstein PSS9 on other cars. They've all been really good.
468, Mishimoto rad + oil cooler, TSP LTH
MCS 2WNR CTSV/ZL1 front calipers/rotors + G-Loc Forgestar CF-5 19x11 |
10-05-2019, 07:25 PM | #3 |
Drives: 2010 2SS/RS Join Date: Dec 2009
I have a set of PAFDT bushings and no noise.
Orange Krush II
10-06-2019, 06:46 AM | #4 |
Drives: 2015 Z/22 Join Date: Aug 2015
Minimal to no extra NVH after adding solid bushings. Dooo iiit!
JusticePete always spoke highly of BMR and DSE springs with B6's, suggesting that this combo is better than many of the lower-priced coilovers.
10-06-2019, 09:00 PM | #5 |
Drives: 2020 ZL1 1LE Join Date: Sep 2012
Slightly more noise, but you really have to be listening for it. For street use, you'll notice more control with 1st/2nd gear hard acceleration as the wheels aren't able to move the cradle around and steer the car from the rear.
2020 ZL1 1LE [Moroso SC Expansion Tank, otherwise stock]
10-07-2019, 05:55 AM | #6 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
I was just shopping for cradle bushings friday. I can see how a step up from the soft factory rubber to a stiff poly bushing could be worth $200, but I just dont see the gain from going from poly to a solid bushing for an additional $400+.
Unless you guys are finding them cheaper somewhere? Then again, I've never tried either... BMR's are in route now.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
