01-27-2012, 01:08 PM | #1 |
Drives: 2010 Camaro 2SS/RS,LS3 Join Date: Oct 2010
Need Help with relocating IAT Sensor
I need help with the relocation of the IAT sensor. I have ProCharger D1SC with a meth kit and I want to install the IAT sensor after the meth injector to get the full benefit of the meth. I installed it on the rubber hose with a grommet but under boost it blows right out. I reordered the 3.5" to 4" rubber tubing, but I need some input on where to install it for the best benefit. I would like to know if theirs any adaptor for the sensor to be threaded on to the intake tube. Here are some pics.
LS-3, ProCharger D1SC 665. rwhp /562. rwtq @ 9.3 psi |
01-27-2012, 01:25 PM | #2 |
USAF retired! Thank God!
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28 Join Date: Jul 2011
Manny, what is getting blown out? The grommet or the sensor from the grommet? If its the sensor you could dab a little epoxy on the sensor and insert it into the grommet. Again, just a dab so you could remove it later with a little effort. I did not use a grommet with mine. It is just crammed into a very small slit in the sleeve and it hold fine. i have been up over 11 psi more than a handful of times
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
01-27-2012, 01:27 PM | #3 |
[/IMG]
[/IMG]
01-27-2012, 01:30 PM | #4 |
here is how i have mine setup
01-27-2012, 01:38 PM | #5 |
I tried to copy your set up, but at the time I didn't know that you didn't use a grommet.
01-27-2012, 01:51 PM | #6 |
Bull Last night I was looking at a magazine and saw a sensor with a brass fitting that was threaded on to the intake tube. I would love know if it was a IAT sensor.
01-27-2012, 01:54 PM | #7 |
Im gonna go pull mine and take some pics so that when your new sleeve shows up you can set it up. stand by
01-27-2012, 01:58 PM | #8 |
Thanks! The hole is to big now to try what you did. I should get the new sleeve by Tuesday. I also ordered the 4.13 pulley
01-27-2012, 01:59 PM | #9 |
The hole is about 1/4" and the sensor inserts with quite a bit of resistance. I estimate the force required to remove it is a good 10 lbs worth of pull. Its in there pretty good. Nice catch can, here's mine!
01-28-2012, 07:58 AM | #10 |
Bull after you relocated your IAT sensor what is the difference in IAT when the Meth is not on? Is it about same or higher
01-28-2012, 08:13 AM | #11 |
Yes you can get a screw in IAT sensor and a bung. That is what I did on my car.
2000 corvette IAT sensor that I grabbed from carquest or any autoparts store. Then just a weld in aluminum bung.
Nick
Corvette Z06 -1200ish rwhp |
01-28-2012, 09:19 AM | #12 |
Unreal thanks for the info
01-28-2012, 09:50 AM | #13 |
Car Lover By Nature
Drives: 2016 Hyper Blue Metallic SS Join Date: Dec 2009
correct me if I'm wrong but.........
wouldn't having your IAT sensor after your meth nozzle cause problems? I mean, wouldn't having the meth spraying on your IAT not be good for it? am I right?
01-28-2012, 12:03 PM | #14 |
You want the IAT sensor to read the temp drop from the meth so you ECU can adjust timing for the meth. It won't hurt the sensor. The sensor is just a ceramic tipped thermister that just changes resistance based on temp. You can submerge it in liquid all day long without hurting it.
Nick
Similar Threads | ||||
Diagnostic Trouble Codes (DTCs) for OBD II equipped GM vehicles | steeleshark2 | Tuning / Diagnostics -- engine and transmission | 11 | 04-08-2020 10:49 PM |
irpq11 has permagrin...updated with vids..... | PQ | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 198 | 01-15-2014 12:23 AM |
What do all the abbreviations mean? | CrzyGamr2 | 5th Gen Camaro SS LS LT General Discussions | 77 | 12-07-2012 04:34 AM |
CEL - P1682 | PSU SS | Tuning / Diagnostics -- engine and transmission | 4 | 09-29-2011 07:27 PM |
Tire Monitoring System | monevz28 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 7 | 11-22-2009 03:42 PM |
