Old 02-12-2012, 08:04 PM   #1
BigBlue2010
BigBlue2010's Avatar
Drives: 2010 Camaro 2SS/RS IBM A6
Recommended Oil Filter
I tried looking. I know it has probably been posted and discussed before. Frankly, don't feel like wasting any more time looking for it. What is the best oil filter for the V-8?
BigBlue2010 is offline   Reply With Quote
Old 02-12-2012, 08:22 PM   #2
Blue17CamaroZL1
650HP soon to come
Blue17CamaroZL1's Avatar
Drives: 2017 Chevy Camaro ZL1
I don't know specifically what's the "best" but I use the K&N HP-1017
2017 Camaro ZL1
Hyper Blue Metallic
A10, PDR, NAV, Premium floor mats
Blue17CamaroZL1 is offline   Reply With Quote
Old 02-12-2012, 08:52 PM   #3
Russell James
Russell James's Avatar
Drives: two 5ths and a 1st
From the owner's manual - pf48
Been using AC Delco filters for decades, never seen a reason to use anything different from what the engineers spec'd for it. It has the right micron filter rate, the right anti-drain back valve... warranted by every GM dealer in the country (match that one with any aftermarket filter). Not that the warranty will ever be needed, I've never seen a bad AC Delco filter.
Old 02-12-2012, 08:55 PM   #4
ron10
Drives: 2010 2SS IOM L99
i use the mobil1 filter.there are a lot of good filters out there.if you are using synthetic oil as i am,be sure and get a synthetic oil filter.
Old 02-17-2012, 07:59 AM   #5
Grabber
Just a car guy
Grabber's Avatar
Drives: 2016 Durango R/T AWD
I suggest looking at Royal Purple, mobil 1, amsoil and k&n oil filters. Those are basically the best on the market, and from what I've seen, the RP and Amsoil filter have the best filtering and durability.
Sent via morse code through a fax machine.
2014 5.0 - Ported CobraJet Manifold - SCJ Mono-Blade TB - Kooks 1-3/4" LT Headers - Kooks O/R H-pipe - Custom Intake - McLeod clutch line - Borla S-Type Axle Backs - AED Tuned - 443 RWHP / 388 RWTQ - GONE
05 GT - Sold
03 Cobra - Gone (Never Forgotten)
Grabber is offline   Reply With Quote
Old 02-17-2012, 08:32 AM   #6
NavyDood
Retired Navy
NavyDood's Avatar
Drives: 2010 2SS/RS
In order of best to less IMO.
1. Amsoil Ea15k50 (Guarantee's 15K)
2. Mobil M1, Royal Purple, Bosch Distance plus, Napa Platinum (no particular order)
3. K&N, Purolator PureOne, Fram Xtended Guard
4. Napa Gold, Baldwin
5. Reg Napa/Wix, ACDelco PF or UPF
6. All others
Retired Navy... A Husband. A Dad. A Veteran as of 2011. 2010 2SS/RS A6 - FlowMaster CatBack - I'm not a Amsoil dealer and will never be one. I believe in its capabilities from personal use with oil analysis reports backing up my OCI's. Besides, I know more than most cut and paste Amsoil dealers which are at least 95% of them.
NavyDood is offline   Reply With Quote
Old 02-17-2012, 08:44 AM   #7
Russell James
6. All others
ACDelco tied for 5th?
Beaten by Fram and Purolator....
In many years as a dealer tech ... never once saw a problem with an ACDelco filter. Can't tell you how many Purolators and Frams had problems.
There is only one filter in that list that was spec'd out by the engineers that designed the engine, and the only one covered by the factory warranty. Show up at a dealer with any other brand with a problem, and here's your estimate. Seen that happen countless times.
Most memorable was the Purolator air filters that shed fibers that burn onto the MAF hot wire. New MAF...$$$$ very pricey on some cars. Then we saw tons of off brand oil filters with the wrong anti-drain back valve, causing cold start knocks.
It's your car and money, spend as you wish and enjoy.
Old 02-17-2012, 08:53 AM   #8
blackknight
Camaro Lover
Drives: 2014 GMC Sierra 5.3L
Amsoil makes great filters as well. Part number EA15K50. They are a bit expensive. But worth the extra coin to keep your oil filtered well.
No Camaro right now. But I'll be back in one in a few years.
blackknight is offline   Reply With Quote
Old 02-17-2012, 12:53 PM   #9
crd2daniel
Drives: 2011 Camaro Convertible 2SS/RS LS3
Here's a comparison video of some different filters
http://www.youtube.com/playlist?list=PL9A27085C060C2436
crd2daniel is offline   Reply With Quote
Old 02-17-2012, 01:19 PM   #10
Andy@AMSOIL
Drives: 4 wheels
AMSOIl EA filter in my cars, oil comes out nice and.clean after a couple thousand miles
Andy@AMSOIL is offline   Reply With Quote
Old 02-17-2012, 01:24 PM   #11
MMC
MMC's Avatar
Drives: CGM 2SS/RS, 1987 & 2014 Silverado
AC Delco Ultragard UPF48R. This filter requires a different wrench that a UPF48. High pressure canister same as on the ZR1 & Z06.
MMC is offline   Reply With Quote
Old 02-17-2012, 01:49 PM   #12
Cpanthers85
Drives: 2011 Camaro 2SS RS
What makes it "high pressure"? Educate me.
2011 2SS/RS L99
2017 Chevy SS
1979 Z28
Mods: Kooks Long Tube Headers, RotoFaB EForce CAI, American Thunder Catback Exhaust, PFADT Stage 1 Drag Kit + Front Sway Bar, GM Strut Tower Bar. ZL1 Fuel Pump. Nitto NT05R. RX Catch Can.LS9 Cam and Springs.LS3 Conversion.JRE Fuel Rail Upgrade.Edelbrock Eforce.60# Eforce Injectors.Extreme Racing Tune. 523/495
MY BUILD THREAD
Cpanthers85 is offline   Reply With Quote
Old 02-17-2012, 02:15 PM   #13
Russell James
Thicker canister. Needed when the '09 Z06 and ZR1 went to a high volume/ high pressure pump.... if the motor was hammered on when cold could really make some high pressures.
As stated below in the info, the UPF48R can be used on a PF48 application, internals identical..... but a waste of money if you don't have an '09+ LS7/9.
The LS3/L99 will never have oil pressures anywhere near the burst spec of a PF48 (which is 5X's the engines normal pressure)
Again, pays to read the owners manual to avoid wasting money.
"GM Powertrain has released a new oil filter for the 2009 Corvette. The new design UltraguardTM Gold UPF48R oil filter will be used on the following OEM applications:
"Z06 - LS7 7.0L and ZR1 - LS9 6.2L
"According to GM, this filter was designed with the following in mind: “With the addition of piston oil cooling nozzles and other unique lubrication system requirements, a new design dual-rotor oil pump is required for the LS9 application. The new design oil pump produces greater volume and higher system oil pressure. To meet those requirements, a new oil filter with higher BURST strength is required.
"The UltraguardTM Gold UPF48R filter (U is for Ultra and R is for Racing) is black in color, has a thicker exterior shell and can be identified as GM part number 12626224. The internal components are the same in both the UPF48R and the PF48 oil filters. The UPF48R can be used in applications where the PF48 is specified.
"GM requires the UPF48R for the LS9 application and is also used for the LS7 application as both engines are built at GM’s Wixom Engine Performance Build Center."
Old 02-17-2012, 09:22 PM   #14
Big Daddy Kane
Big Daddy Kane's Avatar
Drives: Red 1SS
Amsoil filter user here.
Kooks LT Headers/catback exhaust, E-force supercharger, JRE fuel line upgrade, JRE differential, 3.91 LPE gears, Roto-fab intake, JRE tune, DSS Carbon Fiber driveshaft, MGW shifter, Hotchkis chassis braces
Big Daddy Kane is offline   Reply With Quote
2010 Camaro V6 Oil and Oil Filter Change azamazonqueen Camaro DIY & HOW-TO instructions & discussions 116 03-19-2017 01:36 PM
My V6 oil change experience convert Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 38 04-08-2014 04:15 PM
A NEW generation of oil, for ALL GM cars Sir Nuke 5th Gen Camaro SS LS LT General Discussions 48 11-03-2010 09:33 PM
First oil change? Fogey Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 27 09-18-2010 06:50 AM
GM's OLM & synthetic oils. duder4thgen Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 03-24-2010 11:37 AM
