10-12-2018, 09:24 AM | #1 |
Drives: 2015 1LE Join Date: Oct 2015
LS3 Clutch Weight?
Anyone know the weight of the LS3 clutch assembly? This would be flywheel, pressure plate and clutch disk.
10-12-2018, 09:31 AM | #2 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
57-58 pounds I believe all together
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
10-12-2018, 03:28 PM | #3 |
&*!#&*( heavy lol These cars should come with nothing heavier then a 32 pound clutch set up.
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85 Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE 10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake Best 1/8 6.80@105.75 Best MPH 134.82 |
10-12-2018, 05:14 PM | #4 |
Well, I need to do a clutch and dont have the money to do a $2500 dollar clutch. Carolina Clutch has a package with a LS7 clutch and a lightweight flywheel that weighs 42 lbs total. Not a huge savings but its something and it all costs $650. Looks like it should hold my 485 rwhp and 445 rwtq OK. Hard to make up my mind.
10-12-2018, 06:13 PM | #5 | |
10-12-2018, 06:31 PM | #6 | |
I do romp on the car a lot on the street, thats why I want to lighten up the clutch assembly but how much is too much? I have no idea really. |
10-12-2018, 07:53 PM | #7 |
Nothing lighter then 32 pounds stock gear and 24 pounds with gear unless your like me and dailyed a 16 pound one.
10-12-2018, 09:12 PM | #8 |
Drives: 13' 1LE Join Date: Apr 2012
It is almost 60#. I run a 18.5 lbs clutch and its amazing how fun ia the car now. Id look into Spec/Quarter Master clutch or anything between 25-30# on the streets. You can upgrade the clutch material to have better drivability.
I remember Spec had nice 25-28lbs cheap clutch kit, single disc. Mine is a Mini Twin. I would not recommend for a DD or without gears& light wheels.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
10-12-2018, 09:46 PM | #9 |
so many people recommend the heavy clutches im nervous to get a light weight one. Monster makes nice clutches but the single disk ones are almost the same weight as the stock stuff with their 18 lb flywheel. The owner said he does NOT recommend the lightweigh flywheel for the street. $uck this dump truck weight clutch.
10-13-2018, 07:12 AM | #10 | |
10-13-2018, 09:26 AM | #11 | |
Drives: 2015 Camaro SS/RS 1LE Join Date: Jun 2016
I have a 2015 SS 1LE with the OEM clutch, and believe me, its easy peasy compared to pushing a Kenworth W900 clutch that pulls 160000 lbs daily. |
10-13-2018, 09:33 AM | #12 |
LOL, I am not worried about the pedal effort, I want to reduce the rotating mass to free up power. My 1LE clutch is supper easy pedal push too!
10-13-2018, 01:57 PM | #13 |
10-13-2018, 02:36 PM | #14 |
I think I am going to do the Monster level 2 single disk. Its overall weight with the lightweight flywheel is 11 lbs lighter than the LS3 factory assembly (from what I read it should free up about 8 rwhp) and will hold 550 rwtq (car makes 450 rwtq). Its priced around 750 which is in my budget and gets great reviews.
Ya a RPS Billet Twin would be nice and free up more power but I just simply cant afford a $2500 clutch. |
