Old 06-14-2010, 07:14 PM   #1
sexystreetmachine
Go Baby, GO!!
sexystreetmachine's Avatar
Drives: 2010 2SS/RS, 1968 SS, 1993 Z28
Question 3.73 vs 4.10 gears
Ok, i know theres been alot of discussion on this topic, but i didnt quite find a direct answer to my questions. Does anyone know quarter mile differences between stock and 3.73 gears or stock and 4.10's? What about 0-60 times? also what would you folks recommend as a gear change... 3.73's or 4.10's? It's a daily driver but I give her a few taps on the pedal every now and then I'm not super concerned on milage, My previous car was a 8mpg guzzler so anything beats that. I want some tire shredding power, can I get more of that to the ground with a gear change? Sorry im not super familiar with a gear change since Ive never done one. Thanks!
sexystreetmachine is offline   Reply With Quote
Old 06-14-2010, 07:37 PM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Is your car a manual or an auto?
By the way, welcome!
Old 06-15-2010, 12:54 PM   #3
KungFuHamster
KungFuHamster's Avatar
Drives: Black SS
id say a 4.10 is better for these cars because theyre heavy.
KungFuHamster is offline   Reply With Quote
Old 06-15-2010, 02:13 PM   #4
Apex Motorsports
There is a lot more to it than that. My general recommendation is 3.73 for the auto and 4.10 in the manual. Transmission gearing makes a big difference.
Old 06-15-2010, 02:37 PM   #5
jagan323
I have no life
jagan323's Avatar
Drives: 06' Subaru STI, ex-Camaro V6 LLT
what are the stock gears on the V6 A6? I might have to experiment with your recommendations
jagan323 is offline   Reply With Quote
Old 06-15-2010, 02:44 PM   #6
sexystreetmachine
Go Baby, GO!!
Thanks for the quick help! It's a six speed, also the car has an open exhaust and a rotofab CAI. How is first and second gear with 4.10's?
Old 06-15-2010, 02:51 PM   #7
I can't wait to get 4.10's in mine.
Old 06-15-2010, 02:56 PM   #8
Apex Motorsports
Stop waiting, let's make it happen! Hit me up when your ready.
Old 06-15-2010, 05:34 PM   #9
sexystreetmachine
Go Baby, GO!!
Here are the ratios for the V6
First Gear - 4.48:1
Second Gear - 2.58:1
Third Gear - 1.63:1
Fourth Gear - 1.19:1
Fifth Gear - 1:1
Sixth Gear - .75:1
Final Drive (Rear End) - 3.27:1
Old 06-15-2010, 05:36 PM   #10
sexystreetmachine
Go Baby, GO!!
I want 4.10's. Who do I talk to
Old 06-15-2010, 06:47 PM   #11
deckerlt
deckerlt's Avatar
Drives: 2010 2ss Black/Inferno Orange
I have 4.10's installed in mine, you don't have to gas it when you let out the clutch and when you get into it get ready b/c your gonna be doing a lot of shifting, the hurst short throw helps alot, it really loves 3rd and 4th gear. Not a big change in gas mileage I'm getting 21 on the highway, Make sure you also get the full install kit, I ordered mine from Phastech great people to deal with and they had both the gears and install kit in stock. You are gonna need a tuner or someone that can adjust the speedo also. If you plan on doing any forced induction I'd stay away from 4.10's due to rev limit at least that is what I have been told. Good luck...
deckerlt is offline   Reply With Quote
Old 06-15-2010, 06:58 PM   #12
KungFuHamster
Drives: Black SS
lol...true...i posted under the assumption it was a manual
Old 06-15-2010, 07:10 PM   #13
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
also if you hae a sc ls3, you will redline so fast.. also with a sc , getting traction is impossible.. with much lower gearing your tires will break loose that much faster...i would stick with 3.73.. from posts i read the 4.10s can be loud and also with good hp, the 3.73,s are outrunning the 4.10.. imo..more shifting does not equal better 1/4.. if road racing than 4.10 may be better as you can get more sweet spots in each gear and keep rpms higher coming out of turns..
mikepage0007 is offline   Reply With Quote
Old 06-15-2010, 07:13 PM   #14
mikepage0007
Drives: 2010 camaro
. If you plan on doing any forced induction I'd stay away from 4.10's due to rev limit at least that is what I have been told. Good luck...[/QUOTE]
sorry i missed this.. i also agree ..i have around 2-3 seconds between shifting 1-2-3rd and i have stock rear gears. i am sc , and pzeros break loose bad in 1st and 2nd, not so bad in 3rd
4.10 or 3.73 Gear & Install Kit Combo Apex Paul Transmission / Driveline 21 08-21-2010 01:55 PM
Richmond Rear End Gears - 3.73 & 4.10 Sean@Phastek Transmission / Driveline 0 06-02-2010 10:47 AM
Richmond Gears 3.73 4.10 SupremacyCustoms Transmission / Driveline 12 05-20-2010 10:04 PM
Richmond 3.73 & 4.10 Gears On Special! Jason 98 TA Transmission / Driveline 14 02-24-2010 11:03 AM
NEW PRODUCT: 2010 Camaro Richmond Gears - 3.73 and 4.10 Ratios tbyrne Transmission / Driveline 9 01-11-2010 10:36 AM
