Old 07-08-2012, 05:56 AM   #1
debo
debo's Avatar
Drives: 2012 1SS Black on Black
black oem 21' ea279 rims on a black camaro?
I did a few searches on this and cannot find an image. I want to put black rims on my car and I found a set of these rims and tires used for 2k but i'm not sure how they would look on my car. Does anyone have these rims or a picture of them on a black SS?
Thanks
Debo
debo is offline   Reply With Quote
Old 07-08-2012, 09:39 AM   #2
oldfriend
Drives: Fiat 500 E
21 inches tires are very expensive , you still have time to look into other options
Old 07-08-2012, 09:43 AM   #3
first one
first one's Avatar
Drives: SSRS - black, GFX, SSX wheels
I've got several pics on my page.
first one is offline   Reply With Quote
Old 07-08-2012, 03:15 PM   #4
vandervortadam
Drives: 2010 Camaro 2ss black 21's
I will post some when i get home. Black 21's on my ss.l
vandervortadam is offline   Reply With Quote
Old 07-08-2012, 05:52 PM   #5
hightower
LS3 Black Widow
hightower's Avatar
Drives: 2012 45th 2SS LS3 and 1968 Mustang
Tires are pricey for odd number rims. Keep that in mind.
hightower is offline   Reply With Quote
Old 07-09-2012, 05:48 AM   #6
debo
debo's Avatar
Thanks for the pictures first one. I appreciate it. I didn't realize the 21' tires cost so much more than the 20's.(thanks old friend / hightower) This set only has 50 miles on them though, do you think 2k is a fair price? Im thinking they would last for a while, its not a daily driver.
Old 07-09-2012, 05:57 AM   #7
debo
debo's Avatar
just to clarify, the 2k is for a brand new set of rims, tires and tpms. Basically they guy bought the car with the 21' kit on it and had them take it off and put the 20' oem kit on it? not sure why.
Old 07-09-2012, 07:46 AM   #8
Rip
Drives: 2011 SS/RS
The tires alone cost between 2300-2500.
Rip is offline   Reply With Quote
Old 07-09-2012, 08:20 AM   #9
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
What are your goals with your car?
The OEM 21" wheels are very heavy. GM even stated that they slow the car down by .2 in the 1/4 mile (that equates to 20hp).
Something to think about if you're into performance.
Old 07-09-2012, 12:57 PM   #10
Grandeos
Automotive Designer
Grandeos's Avatar
Drives: 2011 Camaro 2SS/RS (LS3)
You should also know that these wheels are poorly offset. You would expect accessory wheels to give your car the proper stance...
BUT NO.
These wheels actually sit more inboard than the stock 20" wheels. I bought spacers to correct the issue and make them flush with the body, but I did not like the instability of spacers/hub-adapters. So I will be buying some 22" wheels soon with a proper offset.
Just want to let you know... Becuase if I knew they were not flush with the body, I never would have bought them.
2011 Camaro 2SS/RS LS3 (SIM/BLK)
Grandeos is offline   Reply With Quote
Old 07-09-2012, 01:21 PM   #11
Obzen
Pull up Cougar!
Obzen's Avatar
Drives: 2016 2SS
BUT NO.
Wow more inboard? Crazy. That's one of the top reasons I wen't aftermarket. I didn't like how far in the stock SS wheels were and these are worse? Bummer.
Obzen is offline   Reply With Quote
Old 07-09-2012, 02:44 PM   #12
Grandeos
Automotive Designer
Grandeos's Avatar
Yea, its pretty bad. Annoys me every time I look at the car. And lowering it just made the bad offset more apparent.
To look good, they require 25mm spacing in the front, and 15mm in the rear.
I could have gotten longer studs to use the hub adapters as just spacers, but since I have to change my wheels every 6 months, this was not a feasable option, as the offset for the stock wheels are different.
BUMMER indeed...
Old 07-09-2012, 05:03 PM   #13
debo
debo's Avatar
wow, these wheels don't seem to be the route to go. The rims cost more, have more expensive tire replacement costs, they rob performance and have a bad offset. I think i'm going to pass. Thanks for the help, i'm a motorcycle guy and im just getting into cars. I guess I have a lot to learn.
