#Camaro6
Old 08-23-2016, 12:44 PM   #1
MiamiBlueCamaro
MiamiBlueCamaro's Avatar
Drives: Gen 6 Camaro RS
Camaro ZL1 Will Hit 60 mph in First Gear
Could mean mid-3 second 0-60 runs.
Per Road and Track:
With a 650-horsepower V8 under the hood, we already knew the Chevrolet Camaro ZL1 would be fast. And with line-lock, it'll be one serious burnout monster. But it'll also have another trick up its sleeve that should make it incredibly quick—the ability to hit 60 mph in first gear.
As [the video below shows], the Camaro's head engineer Al Oppenheiser said that a ZL1 equipped with a manual transmission won't need to shift during a 0-60 run. With such tall gears, you can expect performance figures to be even more seriously impressive.
For comparison, the previous Camaro ZL1 had 60 fewer horsepower, weighed 220 pounds more, and could still hit 60 mph in 4.0 seconds. While exact figures still have yet to be released, the new one is rumored to do that in a scant 3.5 seconds.
MiamiBlueCamaro is offline   Reply With Quote
Old 08-23-2016, 01:47 PM   #2
mkorgan
Drives: 1970-1/2 Z-28, 2017 ZL1
0-60 without having to shift....oh my.
mkorgan is offline   Reply With Quote
Old 08-23-2016, 01:49 PM   #3
HumanWiki
Drives: Car
Either raised the RPM fuel cutoff, or we're looking at 2.39:1 or higher 1st gear then, to hit 60MPH in 1st.
Been talked about a bit here in other threads.
HumanWiki is offline   Reply With Quote
Old 08-23-2016, 02:51 PM   #4
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
If I remember correctly, Al said that they found they were extremely close to hitting 60 in 1st while the car was under development, so they finagled things a bit (99% sure it was the fuel cutoff being raised a hair, instead of a gearing change) and now it does.
Mostly its going to help with 'hero runs' and magazine testing, as most people will be shifting before that when at the drag strip
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 08-23-2016, 06:08 PM   #5
Hypertrophy
Hypertrophy's Avatar
Drives: truck
cool
Hypertrophy is offline   Reply With Quote
Old 08-24-2016, 11:14 AM   #6
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Didn't he say 3.73s for A10s and M6s? If so, I'm with 'Wiki - probably a mid-2' ratio for first gear to wind out to 6500 past 60. That should keep it within a squeak of the A10s 0-60 it seems to me. And I'm not complaining for stock tires on an unprep'd surface. That's DANG good.
'20 ZL1 Black "Fury"
Old 08-24-2016, 11:21 AM   #7
trublucamaro
trublucamaro's Avatar
Drives: 1967 Camaro
I believe the ass-end is gonna have 2.85, and this is shown in the 'printbook' for the ZL1 info
My video posted in my other thread actually shows him talk about this 0-60. Not sure why the OP tags my part one video as it doesnt have him say this. I can't remember if he mentions the gearing.
1967 Base 327 - numbers matching 10C car - (TruBlu - Marina Blue inside and out, still own)
1986 Base V6 - 1987 (Calif.) RS - 1995 Base V6 (all sold)
2017 2SS “Tribute FIFTY” in Blue (HBM, 56R, 5VM, MX0, F55, NPP, RN2, RZ9, S0O, S0V, IO6 Tribute RPO: BR9, FTJ, 56Y, CJL)#teamBeckyD
trublucamaro is offline   Reply With Quote
Old 08-24-2016, 11:40 AM   #8
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
AH HA!!! OK. It was your videos I was watching I think. NICE. Thank you for those!!!
OK. Well - it's right there. I must've thought I heard something else about the 3.73s, but the M6s are getting it, so I didn't screw that up too much.
Old 08-24-2016, 11:43 AM   #9
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I think C6 ZR1s got a low 1st gear, like 2.40 or something, in order to run to 60 without shifting... Those were running 3.42s, though I think, but on shorter 26-inch tires, whereas I imagine ZL1 will be running a few inches bigger like last generation.
Old 08-24-2016, 05:55 PM   #10
Mário Matos
Drives: Camaro ss
60 mph
I think the ratio of the differential can be from 3.31 to run 60 miles without making the switch to second gear
Mário Matos is offline   Reply With Quote
Old 08-24-2016, 06:01 PM   #11
HumanWiki
Drives: Car
This thread has been covering this information
http://www.camaro6.com/forums/showthread.php?t=462979
