06-10-2017, 04:43 PM | #1 |
Drives: 2014 2SS 1LE AGM Join Date: May 2013
FS: RX Catch Can LS3
RX Catch can for sale. Comes with all parts and mounting bracket. Asking 100.00.
Message me if you have any questions. SOLD!
06-13-2017, 01:07 AM | #2 |
Drives: Chevrolet ss Join Date: Sep 2016
Let me see if it fits my Chevy ss I need a catch can
06-15-2017, 11:05 AM | #3 |
USA-1
So to drain the fluid you just turn the orange lever at the bottom?
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
06-15-2017, 11:33 AM | #4 |
Correct.
06-15-2017, 10:31 PM | #5 |
USA-1
Do you know if this will fit a L99?
06-16-2017, 09:40 AM | #6 | |
"Old School"
Drives: 2010 2SS L99 Join Date: Apr 2015
That will fit an L99, but you will need a longer hose to attach to the inlet since the spot you need to hook up to is at the rear of the motor on the drivers side. The L99 is a little different that the LS3 in this way. See the video below I made for L99 catch can installation.
06-17-2017, 05:27 PM | #7 |
Bump. Still for sale.
