#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > V8 LT1 Engine, Exhaust, and Bolt-Ons
Old 10-17-2020, 12:52 AM   #1
Brandonc_06
Drives: Chevy Camaro 2017
Ls7 Lifter & TspVVT3 cam
8kmiles now with the .645/.635 cam. Took it on a roadtrip From texas to LA & back. No issues so far. Just curious when should I replace the ls7 lifters I installed with the cam. I have titanium dual valvesprings so I don’t plan on replacing them till maybe 35k+ miles since those can handle up to .660. Or any recommendations? To keep it reliable with this big cam.
Brandonc_06 is offline   Reply With Quote
Old 10-17-2020, 01:32 AM   #2
Fast6.3
Fast6.3's Avatar
Drives: 2016 2SS coupe 2015 3LT Stingray
I would go with johnson or morel lifters ls7 lifters are not designed for those spring pressures high lift cams
Ported intake manifold and throttle body kooks 2" headers no cats
Fast6.3 is offline   Reply With Quote
Old 10-17-2020, 02:13 AM   #3
Brandonc_06
Would I have to get new trays as well? I have ls7 lifter & trays
Old 10-17-2020, 08:00 AM   #4
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Depends on what you go with...both Johnson and Morel make drop-in lifters that work with factory trays.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP
Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA
KingLT1 is offline   Reply With Quote
Old 10-17-2020, 08:05 AM   #5
6spdhyperblue
Drives: 6th gen
I’m gonna go ahead and say if it sounds and runs ok, don’t touch it. Ideally you run the appropriate lifter from the start but no way I’d tear into it until first signs of an issue. Plenty of ls7 lifter cars out there surviving.
‘22 2SS 1LE M6 Summit White - RF, Flexfuel, LT2 intake, 95mm tb, ATI udp, VT ramair, full 28” dragpack - 11.68@122
‘16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold)
6spdhyperblue is offline   Reply With Quote
Old 10-17-2020, 01:16 PM   #6
Brandonc_06
I just started learning more about internals. I don’t want the ls7 lifters failing on me and then it breaks my cam or something. Was hoping maybe someone with better knowledge than me would know if im fine or not fine. Its stock 6500rpm limit so it’s nothing excessive.
Old 10-20-2020, 12:21 AM   #7
Fast6.3
Fast6.3's Avatar
You can get seop in lifters but I would still chamge the trays rhey are only 10
Old 10-20-2020, 02:50 PM   #8
Tim M
Drives: 2018 Camaro SS 1LE
...titanium dual valvesprings...
I'm a bit interested in these...care to expound?
Tim M is offline   Reply With Quote
Old 10-20-2020, 08:30 PM   #9
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
Or just titanium retainers? I didn't think titanium made a good spring material? Maybe I'm wrong?
cmitchell17 is offline   Reply With Quote
