06-04-2020, 05:46 AM | #1 |
Drives: 2012 Camaro SS Join Date: Jun 2019
Old Oil?
Hey folks, I was getting ready to do an oil change and I found some oil that was left over from one of my past changes. The container has 3 qts left and had the lid on, from me thinking back it's probably 2-3 years old. Is there any harm in using it or should I get rid of it and buy new? Thanks.
2012 Camaro SS LS3, JRE Scoop, CAI intake, Whipple Supercharger, Fast 85lb injectors, ZL1 pump, McLeod RXT clutch, MGW shifter, Stainless Power 1 7/8 headers w/HFC, Ridetech coilovers, BMR sway bars, trailing arms, toe rods, cradle bushing inserts, 2020 Speed Tuned.
06-04-2020, 06:06 AM | #2 |
Drives: 2014 Ashen Gray Convertible Join Date: Apr 2017
My thought is; if your concerned enough to ask then for peace of mind DON'T use it. Oh, if you find a container of gas from the same time frame I wouldn't use that either! Have a wonderful day!
06-04-2020, 06:20 AM | #3 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
It was in the ground for about 100 million years so should be ok.
06-04-2020, 06:47 AM | #4 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
If it wasn't contaminated it's fine
06-04-2020, 06:59 AM | #5 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
I always have extra oil for any number of reasons. It won't go bad.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
06-04-2020, 07:21 AM | #6 |
waiting at the tree
Drives: SIM 2010 2SS/RS A6 Join Date: Apr 2013
2010 2SS/RS A6 ZL1 Rims
60ft 2.03 13.08 at 107.82 (4/28) 2009 Pontiac G8 3.6L the DD |
06-04-2020, 07:23 AM | #7 |
waiting at the tree
Open the lid and look in without jostling it to see if there is any water in from condensation it would be on top of the oil.
06-04-2020, 08:40 AM | #8 |
Thanks for the input! I'm going to go ahead and use it. I don't see any condensation 102SS, thanks for the tip.
06-04-2020, 08:53 AM | #9 |
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ Join Date: Dec 2010
See if the container has an effective date. If you are in a pinch then use it, just change your oil sooner.
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic '15 Malibu LTZ 2LZ Turbo '14 CAMARO ZL1 Blue Ray Metallic |
06-04-2020, 09:07 AM | #10 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
06-04-2020, 09:25 AM | #11 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
06-04-2020, 09:30 AM | #12 | |
Drives: 2011 Camaro SS Join Date: Dec 2016
Manufacturers typically suggest a 5 year shelf life max, though how much of that is marketing and how much is science is an ongoing debate. |
06-04-2020, 09:32 AM | #13 | |
Drives: 2010 Camaro SS Join Date: Oct 2013
That being said I would and do use old unused oil.
2010 Camaro SS RS, Maggie with 3.4" pulley, 60# injectors, ADM dual fuel pumps, ADM Stage 2 Cam with Brian Tooley springs and pushrods, black CAI intake, Stainless Works long tube headers w/gutted cats, ZL1 Diff w/offset bushings, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, BMR trailing arms and toe rods, Hurst short throw shifter, Painted on Hugger Orange stripes, Forgestar F14 Piano Black wheels, Nitto NT05 rubber.
06-04-2020, 09:35 AM | #14 |
