04-07-2017, 06:29 PM | #1 |
Drives: 2011 Camaro SS/RS Join Date: Feb 2011
Eaton truetrav/axle install
Recently got my eaton true trac and gears installed. Now its time to put axles back in and they wont seat all the way. I made sure the c ring was faced down. I get it in about half way and they not mattet how hard i bang it. It wont go any further. The splines are lined and it also the correct part. Anybody else have this problem before. I did make sure the splines were free of debri or for damage. They all seem fine.
SLP TVS 2300- 1 7/8 LG Headers- RDS NX Plate- 75 Shot- No Cats- SLP Loudmouth 2- NW102- 3.8 Pulley- OD Cog drive-12lbs boost-FIC 80# injectors-ZL1 Fuel Pump- RotoFab CAI- Apex CAI Scoop- Pat G Tune- Weld RTS drag pack- BMR Trailing Arms- BMR 1'' Drop Springs-BMR Lower Control Arms- BMR Toe Rods- BMR Rear Cradle Bushings- BMR Upper Control Arm Bushings- BMR Extreme Anti- Rollbar- Hotchkis Subframe Brace- Prosport Evo Boost & F/A Ratio
04-08-2017, 07:02 AM | #2 |
Drives: own more cars than i can list Join Date: Nov 2010
Try taking the snap ring off totally and see what happens.
04-08-2017, 05:25 PM | #3 |
Drives: cars Join Date: May 2011
I used a little grease to hold it in but it definitely took a hell of a lot of push to get things in.
04-08-2017, 06:44 PM | #4 |
My TT takes more effort to engage the axles than the stock posi for what ever reason.
