Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Road Course/Track and Autocross
Old 09-17-2014, 12:08 PM   #1
Z Madness
Z Madness's Avatar
Drives: 2010, 2000, 1971 Camaros
18 inch square set-up for AutoX
Can anyone who is running an 18 inch square set-up provide me the offset and rim style that can clear the stock Brembo's or other confirmed BBK fitments? I have the Stop Tech BBK's so I'm hoping they are similar in size. I would prefer 18x9.5 to 10.5. Main reason for the 18's is so I can use hand me downs from my primary AutoX car (my son should be the primary driver of the Camaro).
I've searched and did not find anything specific other than it appears a couple of guys have an 18 inch set-up. I also PM'd a couple of vendors but they haven't came back with any answers/options after providing them with the specific dimensions of the StopTech BBK's so I thought I would check here. I assume the TSW or Forgestar would fit my needs but just want to make sure.
Thanks!
Z Madness is offline   Reply With Quote
Old 09-17-2014, 01:44 PM   #2
woodside783
Casey Woodside
woodside783's Avatar
Drives: a very fun car
It should fit the fronts I had a set of 18x9.5. I had to replace the front brake pads because of the weights that where on the pads
Instagram @caseywoodside
http://youtu.be/CSc9aPh_X_w
woodside783 is offline   Reply With Quote
Old 09-17-2014, 03:59 PM   #3
Z Madness
Z Madness's Avatar
What offset and or rims did you use? Did you run square?
Old 09-18-2014, 10:32 AM   #4
woodside783
Casey Woodside
it is a forgestar 18x9.5 fronts and 18x10.5 rear. No it is not a squared set up i use it on the streets
i have a set of forgeline 19"x10.5 that i use for autocross
Old 09-18-2014, 05:49 PM   #5
Z Madness
Z Madness's Avatar
Do you have the offset for the18X9.5 front or the offset for the 19x10.5 that fit?
Old 09-22-2014, 03:27 AM   #6
sting808
Drives: 2010 SS RS
Z,
Jon at CCWheels stuck 18x10.5 on a SS rental at Camarofest 1 and it ran AutoX. Had hoosiers and stuck out, but worked well for a stock SS. Not cheap since 1-piece billet. Can call to find out offsets.
Here's the pic of the car. Need to see your car around. Alex and I are lonely in Street Mod. I still got my Pedders 32mm rear SwaybarC laying around if you're interested.
sting808 is offline   Reply With Quote
Old 09-23-2014, 02:28 AM   #7
Z Madness
Z Madness's Avatar
I think I found some Forgestars in 18's. My son should be out there soon, I may run it a couple of times too. Hope we add CAM class next season.
Old 09-23-2014, 03:29 AM   #8
sting808
Drives: 2010 SS RS
I want to verify if CAM is a go for next season. If so, want to use up my R888 and try Rivals or R-S3 V2s. PAX would probably still suck. See you Sunday.
