07-09-2015, 03:53 AM | #1 |
Drives: '16 C7 Z51 Join Date: May 2012
(Probably not a good fit for our cars) The new Amsoil 5W-50!
I think this new oil could make a great track oil since it provides great protection when very hot. HTHS is 4.7!
http://www.amsoil.com/shop/by-produc...?code=AMRQT-EA Kinematic Viscosity @ 100°C, cSt (ASTM D445) 20.3 Kinematic Viscosity @ 40°C, cSt (ASTM D445) 127 Viscosity Index (ASTM D2270) 184 CCS Viscosity, cP @ (°C) (ASTM D5293 5052 (-30) Flash Point °C (°F) (ASTM D92) 230 (446) Fire Point °C (°F) (ASTM D92) 252 (486) Pour Point °C (°F) (ASTM D97) -47 (-53) NOACK Volatility, % weight loss (g/100g) (ASTM D5800) 7.4 High Temperature/High Shear Viscosity @ 150°C, 1.0 X 106 s.-1), cP (ASTM D5481) 4.7 Four-Ball Wear Test @ 40 kgf, 75ºC, 1200 rpm, 1 hr, scar diameter, mm (ASTM D4172) 0.35 Total Base Number (ASTM D2896) 12.6 EDIT: I think this oil is too thick, and in turn will jack up oil temps in track use : (
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD) '13 Mazda MX-5 Club (Build Thread) '17 RAM 1500 Crew Cab 4x4 Night Edition '15 Nissan Rogue S AWD Last edited by X25; 07-14-2015 at 03:29 AM. |
07-09-2015, 01:22 PM | #2 |
Drives: 11 SW SYNERGY SERIES/14 1SS 1LE Join Date: May 2012
Hmm, interesting. I'm running the signature series now, but the red top bottles. Have enough for one more change, then time to reorder. Might make sure I get this one next. Wonder the difference between the two?
2011 Summit White Synergy Series Edition, the hot innocent woman named Ava that we show off around town, dressed in white complete with angel's wings. Sold, but never forgotten.
2014 1SS 1LE. Bama, sporting Red Rock Metallic demon's horns, when we are ready to get naughty and open a can of whoopass! Airaid, Spectre, Xpel,Bowler shifter Peddars, UMI, Ult Perf. Diode Dynamics, JRE Tune, XS Power battery, Hooker Headers Blackheart exhaust,Powerbrake InstaGram & Twitter: @jlouie62 FB: hangtimeracing |
07-09-2015, 01:24 PM | #3 |
Never mind, just noticed the HTHS is lower, like 3.1 vs the 4.7
07-09-2015, 08:05 PM | #4 | |
Keep in mind, GM recommends 5W-30 Z/28 as far as I know, but for track duty, it recommends 15W-50 Mobil1, so chooses to go with the heavier weight.
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD) '13 Mazda MX-5 Club (Build Thread) '17 RAM 1500 Crew Cab 4x4 Night Edition '15 Nissan Rogue S AWD |
07-10-2015, 08:35 AM | #5 |
Drives: 2010 CGM Camaro 2SS/LS3 Join Date: Oct 2013
Everything i've read says for track use and higher oil temps you need heavier weight oil.
The problem is that the viscosity goes down the hotter the oil gets, so if you run a 30 weight it might not have enough viscosity at 250 degrees to properly protect everything.
2010 2SS
BMR 1" Springs Koni Orange struts/shocks 1LE rear sway bar SRP Racing Pedals Hurst Billet short shifter Square tire/wheel setup Elite Engineering Catch Can Stainless Power longtubes/highflow cats K&N Typhoon CAI RPM Motorsports of Garner, NC dyno tune (421 RWHP) |
07-10-2015, 12:38 PM | #6 | |
Drives: 14 1LE Join Date: Mar 2013
LMS Engineering
07-10-2015, 06:51 PM | #7 | |
07-11-2015, 04:09 PM | #8 | |
Drives: 2020 ZL1 1LE Join Date: Sep 2012
Not sure what the max "weight" for this engine is, but it has to be balanced vs having the oil pump go to bypass until the engine is hot. With bypass the engine get's less oil flowing. The 5w- of the Amsoil oil might prevent the bypass during the warm up period. I think that a 40 weight is sufficient in high temps, but oil analysis is the only way to know. The LS3 goes to bypass at a pretty low 50psi. So if this 5w-50 oil generates more than 50psi at track temps and rpms, then I would say it is too heavy.
2020 ZL1 1LE [Moroso SC Expansion Tank, otherwise stock]
07-11-2015, 05:37 PM | #9 | |
LMS Engineering
07-11-2015, 08:17 PM | #10 |
Runs with scissors...
Drives: '14 Z/28s SIM/SW Join Date: Jan 2013
I have a friend who races a Miata in SCCA; he switched over to a synthetic called Maxima -- supposedly used by Dinan and Team Sahlen (Daytona 24) -- and swears by it. I know nothing about this and have had good results with Mobil 1 15w-50, but the spiel goes like this:
Please see the “Buyer Beware” attachment in reference to the differing basestocks that are in the lubricants marketplace. Also, please note that all of our Performance Auto oils are API SG / SJ rated which means that they contain the highest levels of ZDDP and Phosphorus in the industry (2,000+ PPM) which happen to be the backbone for extreme pressure & anti-wear performance. We have supplied oil to the Dinan teams for several years now. We have also been working with Team Sahlen http://www.teamsahlen.com/index.cfm?...s&news_id=5919 so our oils have been used in the 24-hours of Daytona as well. Let me know if you have any more questions and thank you for considering Maxima! Best regards, Tim Schaeffer Maxima Racing Oils
07-11-2015, 08:34 PM | #11 | |
Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
07-11-2015, 11:02 PM | #12 | |
I don't think we hit the high pressure limits at all at the track due to thinning that happens as the oil gets hot (which is why we're trying to find a good -50 oil anyway), but it might be an issue at cold start. Considering the fact that we rarely see any freezing temps, and never see frigid temps, I think 5W-50 might work great here in Pacific Northwest. Now that I know the bypass threshold, I'll also check on the pressures at cold start. I'll check it out once I replace my 0W-40 to give this a shot. Regardless, it's much better fit than a 15W-50, with possibly no need to drain it after the track day. 15W-50 is what GM recommends for Z/28, but I forgot the fact that the dry sump version of LS engines run at much higher oil pressure and they must also have a higher threshold for bypass, too. As such, its minimum viscousity requirements might be different (might be lower or higher). In other words, the fact that it's OK to use it on an LS7 for short term does not necessarily mean we can use it on an LS3, too.
07-11-2015, 11:05 PM | #13 | |
07-13-2015, 02:13 PM | #14 | |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
Bypass is based on pressure differential pre and post filter. You can run 80 psi and have no bypass if the differential is below the valve spec. Which is why racing filters have larger flow/micron ratings. Track days, I run 15w50 high zinc/phos oil and a Wix racing filter. Won't filter down to the nano micron... but that is not important at the track. Film strength and no bypass much more important. Thin oil in a tiny micron filter can go into bypass at high RPM. |
