02-13-2020, 02:36 PM | #1 |
Should I replace the slave cylinder?
I have a 2011 SS m6 (65k miles). The engine is out and wondering if I should just go ahead and replace slave cylinder? I thought I read about slave problems from the early 5th gens? I have not had a clutch problem but It would be my luck for it to go out after the car is back together.
02-13-2020, 03:08 PM | #2 |
Drives: 2009 ZR1 Join Date: May 2010
I would.
02-13-2020, 03:37 PM | #3 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
Easy time to do it. Why not!
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
02-13-2020, 04:57 PM | #4 |
Yup that is what i was thinking
02-13-2020, 06:09 PM | #5 |
Big difference in prices on #24266013
Summit has it at $432 GM Parts Direct $285 Tick Performance $278 Rock auto $146 As far as I know #24266013 is the updated on for all v8 manuals. Is there some reason I should not get the $146 one from Rock Auto? |
02-13-2020, 08:27 PM | #6 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
LUK makes them for GM.
More to come. |
02-13-2020, 08:38 PM | #7 |
02-14-2020, 10:01 AM | #8 |
Drives: 2010 Camaro SS Join Date: Oct 2013
Get a billet bearing support from Monster or Tick and ditch the plastic one in your new slave.
Monster sells new slaves with the billet support already installed if you prefer. A remote bleeder is a good idea too.
2010 Camaro SS RS, Maggie with 3.4" pulley, 60# injectors, ADM dual fuel pumps, ADM Stage 2 Cam with Brian Tooley springs and pushrods, black CAI intake, Stainless Works long tube headers w/gutted cats, ZL1 Diff w/offset bushings, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, BMR trailing arms and toe rods, Hurst short throw shifter, Painted on Hugger Orange stripes, Forgestar F14 Piano Black wheels, Nitto NT05 rubber.
02-14-2020, 10:12 AM | #9 |
Bingo pretty much must have items on these cars especially when trans is dropped out.
Car mods: never enough!
02-14-2020, 02:52 PM | #10 |
Bearing support and bleeder already ordered from monster! I ordered the LUK slave from rock auto for about $150
02-17-2020, 10:42 AM | #11 |
Counting down the days...
Drives: Black 2011 2SS/RS Join Date: Mar 2011
Hey guys, just confirming that if one plans to pull out the transmission to replace the clutch, replacing the slave isn't necessary, but a "might as well". Correct?
Tick Performance Custom Cam w/ support mods/BBK LT Headers w/ midpipes/Straight Exhaust/Airaid Cold Air Intake/ZL1 Driveshaft/ZL1 Differential/Hendrix Engineering Offset Bushings/ZL1 Axles/BMR Rear Subframe Bushings/BMR Toe Rods/Carlyle Racing 15" Conversion/Jannetty Winsheild Bottle Scoop/Forgestar 15x10 Beadlocks wrapped in Mickey Thompson Radial Pros
02-17-2020, 10:59 AM | #12 |
SomeguyK
Yes. lf it ain't broke don't fix it. BUT, since your there it is easy to do. I've reused mine plenty of times with no problems. Just make sure to check the throwout bearing for excessive wear and be sure it spins freely. It pops right off, so you can grease it as well.
More to come. |
02-17-2020, 02:10 PM | #13 |
Onyx_Z7 <— Instagram
Drives: 2013 2ss 1le Join Date: Aug 2014
I got the billet ram slave no plastic at all, did this when my old Gm slave went to shit and blew my master cylinder as well. honestly while you’re in there do a tick billet master cylinder and ram slave and be done with it. Heat kills and I learned the hard way lol.
02-18-2020, 08:56 PM | #14 | |
