08-25-2010, 04:38 PM | #1 |
RS 10 SS
95 Z/28 A4 Shift Points for 1320
I have never drag raced my 69 with the LT1/4L60E. The transmission has a Transgo shift kit. I will manually shift the car thru the gears on the track.
Do any of you have an idea what the ideal shift RPM is for this car?
Best 1/4 Mile Run: 11/20/2010 SGMP 13.299 @ 106 mph (2.05s 60ft) Mods to Date: Painted Rally Stripes by Body's by Doug ABM Painted Splash Guards & Engine Cover Tinted Windows by Sunbusters CAI Kit by Cold Air Inductions (installed at C5FestI) |
08-26-2010, 07:02 AM | #2 |
Drives: 2002 WS6 Join Date: Jun 2009
What's the RPM range on the cam? Who makes the cam? Stock or aftermarket?
08-28-2010, 05:50 AM | #3 |
Team Green
How much do you love your Opti?
My car never sees more than 5200 RPM, even though the factory rev limiter 5800. I have a LT1 six speed though. Also, factory 4h gen tach's are off. What are you using for a tach?
'98 Camaro Z28 M6 -Toy
'07 HHR LT - DD |
08-28-2010, 10:53 PM | #4 |
RS 10 SS
More info...
1. GM LT4 Hot Cam Kit. 2. Stock torque converter. 3. Autometer Phantom In dash electrical tach. Input from ECM. 4. ECM tune by pcmforless (perhaps I should ask these guys). 5. 3.73 gears with Eaton Posi unit.
08-29-2010, 11:32 AM | #5 |
Drives: A wrench Join Date: Jan 2010
With an LT4 hotcam you should be shifting out around 5900rpms on the 1-2 and 2-3 shifts.
Back in the mid-late 90's when I was still building LT1's and using this camshaft, we usually saw them peak right around 57-5800. You wanna shift 1-200 rpm past your peak. |
08-31-2010, 06:55 PM | #6 |
RS 10 SS
Bryan at pcmforless suggested putting the trans in Drive NOT Overdrive, stab and steer. Let the ECM do the shifting. I will have to try both.
09-03-2010, 07:23 PM | #7 |
RS 10 SS
I just bought a Gtech to play with. One of the setup values is engine redline. Anyone know the LT4 Hot Cam redline?
Similar Threads | ||||
Shift points | SSCamaro2010 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 9 | 11-18-2011 04:39 PM |
GM: Arguments for a Spring 2011 Z/28 release! | sen10l | Camaro ZL1 Forum - ZL1 Specific Topics | 25 | 04-10-2011 01:39 PM |
4-Sale 2001 Z/28 Show Car A4, t-tops | 01pewterz28 | Autos For Sale / Wanted | 10 | 08-12-2010 08:26 AM |
Shift points | Blacc Mamba | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 7 | 08-01-2009 08:21 PM |
