10-16-2010, 10:41 PM | #1 |
Drives: 2011 1LT RS M6 Black Join Date: Jul 2010
Clutch Question
So today i learned that i really need to invest in a line lock....
(ivan....sell me one lol) I was trying to do a burnout and immediately realized it is difficult for me to do on my 6spd manual transmission... I smoked the clutch pretty good... My question is how much damage did i do? it was just a little smoke but i can still smell the stink of it in the cabin from when i did it at 5 pm (it is 11:40 now) Am i worrying excessively? I tend to do that as i this car Thanks! Tyler |
10-16-2010, 11:00 PM | #2 |
Drives: '15 Z06, '01 NBM SS, '97 SS Join Date: May 2009
On it...lol
You don't have a TC button to turn off on your V6?? That's how it's done!! Hold it down for 10 Seconds and when all the lights are on, it's showtime. Use at your own discretion...not liable for awesomeness or blown clutch. LOL Ivan |
10-16-2010, 11:29 PM | #3 |
Yeah lol but I was trying to hold the brake down like an automatic trans. Burt up the clutch :(
How bad did I hurt it? |
10-17-2010, 07:04 AM | #4 |
Drives: 2011 2SS RS, 1968 ragtop Join Date: Apr 2009
I don't understand why people with manual trans cars are trying to hold down the brake to do a burnout! It's not necessary! This isn't the first post about this.
Listen to Ivan, but don't rev it up to 5 grand--use your head.
1968 Camaro Convertible LS1, T56
10-17-2010, 07:29 AM | #5 |
Majic
Drives: 2018 1LT Black...V6 Join Date: Aug 2010
There is no way to know how much damage you did withoit tearing it down and inspecting it. You didn't help it at all that's for sure. See how it works under normal use now. If it engages smoothly then it is probably ok. If not then you have a problem Were you on a track or just playing? If you were on a track no burnout is needed. Go around the water box and stage.
10-17-2010, 07:46 AM | #6 | |
Red Brick of Vengeance!
Drives: 12 Second Brick Join Date: Jun 2009
10-17-2010, 10:54 AM | #7 |
Majic
"organic" ?? Maybe it's just out of "tune".... sorry couldn't help myself.
"Back in the Day" when clutches were made out of abestos facings they used to stink after a launch. Brake pads were the same. After a hard stop that was all you could smell. In today's "green" world they are organic as Screamin says. I saw one not long ago that came out of a Mustang. He runs it pretty hard and it was glazed. They material was fine but the facing looked like it had been chrystalized. That would lead to slippage I would think. He pulled it because he was putting a Centerforce clutch in it. OP...unless you have issues after the fact I wouldn't worry too mucjh about it. BUT...if you're gonna play, you're gonna pay. |
10-17-2010, 12:01 PM | #8 |
I have no life
Drives: 06' Subaru STI, ex-Camaro V6 LLT Join Date: Apr 2010
What? You still need to hold the brakes down when you burnout in a Manual... If you want to hold the car in place that is... Peelouts won't need the brakes though...
10-17-2010, 12:10 PM | #9 |
Drives: 2010 Camaro 1LT RS Join Date: Oct 2009
I have manual and have no problems doing a burnout without hitting the brake. Eventually yes, the car will move forward...guess I have no desire to peel the layers of my tires off...but it smokes pretty good!
10-17-2010, 12:19 PM | #10 |
Back on the dino-juice
Drives: '10 LS + a few more Join Date: May 2010
A burnout involves more than getting the water to smoke up. Whether you want to burn a layer of tire off or not, if you don't get the tires to heat up they aren't going to give you the best launch.
I wake up in the morning and I piss excellence.
-Ricky Bobby America is all about speed. Hot, nasty, badass speed. -Eleanor Roosevelt, 1936 |
10-17-2010, 01:05 PM | #11 |
Majic
Go to a test and tune. Try it with dry tires. Then go through the water box and burn out. The big thing is get the water off the tires or avoid it.
10-17-2010, 01:38 PM | #12 | |
10-17-2010, 03:05 PM | #13 |
I think I need to have someone show me how to do this first hand...
I need to learn to do a proper launch as i am not very good at them :( It will come with practice i assume... This is not my first manual car (my third)...however the other two are 1966 and 1967 Austin Healey's so i drive them like an old lady lol Any tips (clear and concise ones that is) would be greatly appreciated...thanks for all the input! |
10-17-2010, 05:00 PM | #14 |
Doing a great "launch" is a world away from a "burnout". A burnout just gets you a bunch of (usually unwanted) attention and shreds your tires and your clutch if you do it wrong.
A good launch gives you limited wheel spin to get you off the line quickly, like if you're trying to run the quarter mile. Some do a burnout before they launch at the Christmas tree for improved traction... Try taking off traction control and rev up to 2500 and launch it. See if you like it. Then slowly up the RPM's to what you're looking for. Don't overdo it. Go find your local track and give it a go!
Similar Threads | ||||
Clutch Problem | phenixdragon | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 20 | 08-22-2010 10:51 AM |
Clutch stuck for first time | plastrd | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 7 | 08-16-2010 11:04 AM |
Clutch Question | Mungo | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 5 | 12-14-2009 08:34 AM |
Clutch Question | francone13 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 5 | 11-26-2009 10:28 AM |
Clutch question | Chewy | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 0 | 11-03-2009 10:56 AM |
