10-27-2010, 11:56 AM | #1 |
fuse pull after tune??
Just wondering what effect if any this would have.
thanks in advance for the input
IOM 2SS / RS / LS3 / IO INTERIOR
VORTECH V3 SI SUPERCHARGER JRE UPGRADE KIT AMERICAN RACING HEADERS SOLO MACH-X CAT BACK EXHAUST JRE CUSTOM TUNE EIBACH PRO SPRINGS AND SWAYS CATCH CAN 604 RWHP / 547 TQ |
10-27-2010, 12:00 PM | #2 | |
Drives: '69 SS Convertible Join Date: May 2009
Affectively you are pulling the fuse to make it loose memory and for it to reset the tables itself.
Build Journal |
10-27-2010, 12:00 PM | #3 |
I am the internets.
All the fuse pull does is reset the fuel tables in the event that your dealer put 87 octane in. Unlikely it would do anything after a dyno tune.
10-27-2010, 12:38 PM | #4 |
Drives: 2010 Camaro SS LS3 Join Date: Sep 2010
Tune stays as it is. Fuel trims reset, but they will relearn. I believe there are some other things that reset too which is fine, but the tune is safe.
10-27-2010, 12:45 PM | #5 |
CamaroFans.com
If you are tuned you don't need to worry about the fuse pull issues even if you accidentally put in 87 gas...
10-27-2010, 03:59 PM | #6 |
Drives: 2015 c7 Join Date: Nov 2009
10-28-2010, 06:37 AM | #7 |
Motor Head
Drives: CTS-V Join Date: Feb 2009
It really depends on the tune. The operating system is not visible or tunable with any editor that I know about. The switching logic between the high octane spark table and the low octane spark table is in the operating system not the calibration tables. The thing that causes the switch to the low table is knock. Once the ECM switches to the low spark table it seems unwilling to revert back to the high table.
There two ways that will stop the switch to the low table. Make both the high and low spark tables the same so when the switch happens there is no difference in spark advance. And/or increase the knock delay value so switching to the low spark table doesn't happen as soon.
History Camaro's: 83, 93, 95, 98, & 10.
10-28-2010, 06:44 AM | #8 |
Wuf! Wuf! *Low Growl*
Drives: 2011 2SS/RS M6 IBM/S HUD SR ATAK Join Date: Sep 2010
Doesn't matter.
Run with the C5 Pack!! Semper Fi ! Drive, Drive, Drive!! :flag2:
10-28-2010, 08:58 PM | #9 | |
Motor Head
a. Would doing the fuse pull procedure ruin the tune? Answer - The fuse pull will not change the tune in any way! It does reset all the "Learned" memory registers. This is precisely why it works. ** or ** b. If a tune would fix a slow car that needs the fuse pull procedure done regularly to maintain performance. My previous answer stands - Maybe Yes. Maybe No.
Similar Threads | ||||
Fuse pull? | Rage | 5th Gen Camaro SS LS LT General Discussions | 22 | 06-06-2010 01:08 AM |
Something wierd after fuse pull | shroomjohn | 5th Gen Camaro SS LS LT General Discussions | 13 | 12-14-2009 11:02 PM |
FUSE PULL | CJ Offshoredude | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 1 | 11-26-2009 01:59 PM |
Fuse pull snap??? | fourmz | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 7 | 11-01-2009 08:42 PM |
Fuse Pull? | tradosaurus | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 6 | 10-14-2009 05:28 PM |
