10-28-2010, 11:55 AM | #1 |
Drives: 2010 Camaro V6 Join Date: Dec 2009
Will adding an air intake, headers & exhaust cause car to check engine light?
Will adding an air intake, headers & exhaust cause my camaro to check engine light?
I want to do a couple basic mods but Iam worried that the check engine light will turn on, I do NOT want to get a tune b/c that voids the warranty. Also, To those who have done exhaust headers and CAI , do you really feel a differance? |
10-28-2010, 12:02 PM | #2 |
yes and yes
10-28-2010, 12:06 PM | #3 |
Thank you Earn88hardt
10-28-2010, 12:15 PM | #4 |
Drives: 2010 Camaro LS Join Date: Sep 2009
intake no. headers maybe depends on what you get. exhaust no. and yes you should feel a difference with it all on but not that much.
2010 Summit White Camaro LS / M6 MRT V2.0 |
10-28-2010, 12:44 PM | #5 |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
With shorties, intake, and exhaust, car should feel more "spirited", and you should notice better low end response and power, and likely won't get a CEL. It will definitely add HP and TQ, but won't be a huge difference.
With long tubes instead of shorties you will notice an more of a performance improvement, but a CEL is very very likely.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
10-28-2010, 12:47 PM | #6 |
Red Brick of Vengeance!
Drives: 12 Second Brick Join Date: Jun 2009
Long tube will most certainly throw a CEL... some folks have been able to avoid it with spark plug anti-foulers...
Shorty headers... well, the JBAs are kind of hit and miss... some have gotten CELs while others have not. The problem seems to be he the stacker flange... Folks with the Doug Thorley shorty headers haven't reported any CELs which is probably due to the fact thy don't use a flange, they are welded. A properly installed intake should not cause a CEL... Cat back or axle back exhaust will not cause a CEL.... As for can you feel the difference... the only thing I really could feel was when I installed my Injen CAI... definitely felt the improvement..
10-28-2010, 06:10 PM | #7 |
On my LS3 I have a Cold Air Induction CAI, BBK stainless shorty headers and GMPP "touring mufflers" installed on the factory exhaust pipes, the factory resonators and "H" pipe are still intact. About 4K miles and no CEL.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers, rotors & pads, BMR Trailing & Toe Arms, rear cradle & diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 whls, 275/40/20 & 315/35/20 tires, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console & Grant steering wheel.
10-28-2010, 06:19 PM | #8 |
Drives: 2017 1SS Convertible Join Date: Feb 2010
Most cat-back and axle-back exhausts will not cause a CEL.
Most intakes will not cause a CEL. Doug Thorley Shorty Headers will not cause a CEL and are made in Southern California. All Long Tube Headers will cause a CEL. I have a combination of Intake, Shorty Headers and Cat Back exhaust. It's been over 3000 miles and no CEL.
Performance Mods: Injen Powerflow CAI, Doug Thorley Cat-Back Exhaust, Doug Thorley Shorty Headers, Trifecta Tune, TSW Nurburgring Wheels 20x9, 3.45 Ratio LSD Swap, VMax Black Ice-Olator
Appearance Mods: RiderGraphix LS7 Front Fascia Blackout Vinyl, Gill Insert Vinyl, Rear Deck Lid Vinyl (Gloss Black), Gary's Customs Painted Bowties Coming Soon: BMR Trailing Arms |
10-28-2010, 08:23 PM | #9 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
Magnaflow mufflers and resonated x pipe Airaid v2 intake no cel As Scrming said felt the cai the most shorty's were next and axelback not really but put them on same time as old airaid v1 and engine still new so not a good judge of that. I think the crappy airaid v1 negated the gains/feel I did get from the exhaust though. All work well as a package and worth it to boost up the torque some, the sound and the fun factor |
Similar Threads | ||||
Onstar....a spy???? please comment | dieseldave24v | General Automotive + Other Cars Discussion | 138 | 02-23-2012 01:12 PM |
OIL CATCH CANS | john468 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 5 | 09-16-2010 02:02 PM |
List of Intakes that will work with the TVS-2300 MagnaCharger | JJ2010 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 26 | 03-19-2010 02:11 AM |
Modern Muscle Exhaust and Intake Special | modern-muscle | V8 Bolt-Ons & Tunes | 1 | 01-20-2010 06:46 PM |
Why RAM Air is a myth!!! Long Read (Wall of text) | live2well | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 80 | 11-02-2009 03:34 PM |
