Old 11-16-2010, 04:06 PM   #1
stanwilliams
3000 hp 648 ci beast
stanwilliams's Avatar
Drives: 86 Outlaw 10.5 Camaro, 2SS/RS LS3
Final word on msd boost a pump
Just finished the install of my new Whipple. Skipped the BAP part so I could hear it run. Going to do that tonight if it is worth doing. So does the BAP do any good at all on a new Camaro with the FPCM?? If it is a waste of time then I'll just upgrade to a bypass reg and a pair of walboro's or something down the road. Engine is totally stock at this point less the Blower.
2SS/RS, LS3, 6M, IOM w/black hockey, IO interior, sunroof
mods: ******** setup. Whipple supercharger....Need suspension upgrades now... 4" stroker kit, ARH, cam on my wish list.
stanwilliams is offline   Reply With Quote
Old 11-16-2010, 06:25 PM   #2
old motorhead
Drives: Maggie blown LS3 vette
As long as you have enough fuel flow and pressure, there's no reason at all to fool with a BAP. Do you have enough? Do you have any way of monitoring it? If it runs slightly lean, it will slightly (or majorly) damage your motor.
old motorhead is offline   Reply With Quote
Old 11-16-2010, 06:47 PM   #3
stanwilliams
I've got a WB, Hp tuners, and a fuel pressure gauge in the car. Just haven't drove it yet with the blower, still on jack stands. Guess I'll hook up the BAP since I have it and then see for myself what the press does with it hooked up vs disconnected. Thought someone here would know for sure.
Old 11-16-2010, 06:53 PM   #4
old motorhead
It's going to depend on boost/hp. For a low boost setup, you might be OK. You need to watch it like a hawk. Cast pistons aren't very forgiving when leaned out under boost.
Old 11-18-2010, 08:54 PM   #5
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
Lesson learned regarding fuel delivery....Bite the bullet and make darn sure you have enough fuel and pressure. Here is what happens when you dont.
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
Old 11-18-2010, 09:31 PM   #6
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
wow. What was your fuel setup and boost levels/mods when you did this to your pistons?
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
jsharp is offline   Reply With Quote
Old 11-18-2010, 11:11 PM   #7
Total_Perf_Eng
Total_Perf_Eng's Avatar
Drives: Corvette
Send a message via AIM to Total_Perf_Eng
BAP's work perfectly fine on these cars if you hook them up in the correct location. If not, the car will just pull the voltage back out. They work perfectly fine though.
Total_Perf_Eng is offline   Reply With Quote
Old 11-19-2010, 12:08 AM   #8
TeddyP25
TeddyP25's Avatar
Drives: 2SS
That was my poor piston..Set up was stock internals with e-force, arh headers, adm cai, rmcr tune. Nothing was done to fuel setup, i didnt have the knowledge i have now or would of changed it. I think it was at 9.5lbs avg.. Would of addressed fuel for sure if i knew what was going on.
2SS/RS CGM/BLK GFX MN6418 Stroker.785rwhp/885lbtq.50 SHOT NO2..Pfadt arms,toe links,coilovers,swaybars,end links,engine mounts,dif/sub bushings.MGWshifter.Tick LVL 3.ARH1 7/8 LT's/ARH exhaust.ADM gauges/race CAI.E-FORCE SC.8 rib IW 10%OD.LPE dual pump/module.85lb inj,custom valve covers.RMCR tune.TOOLEY RACING CAM.JRE posi kit.JRE fuel upgrade.RX MONSTER CatchCan.DSS axels/DS.Hammerhead rear, 3:73's. WYOSPEED builthttp://www.camaro5.com/forums/showthread.php?t=115687
TeddyP25 is offline   Reply With Quote
Old 11-19-2010, 01:44 AM   #9
Clint@A.I.R.
Drives: 99' Camaro 404 TT
Agreed ^^^. Fuel is critical, Short bursts in 4th gear on the Dyno to verrify a/f ratio does not show real world results.
Do bap's help, Absolutely. But it's all a balancing act.
Things like larger injectors, meth injection help.
Heat plays a large role, keep the fuel pumps cooler by keeping at least 1/4 of a tank minimum in there if you plan on getting on it. More like 1/2 a tank. Why risk it .
Clint@A.I.R. is offline   Reply With Quote
Old 11-19-2010, 08:34 AM   #10
jsharp
jsharp's Avatar
Well lesson learned I suppose. I am about to get a cam added to my setup and have been told the BAP will continue to be ok for the 550rwhp range on my auto. But I have had a couple tell me intank would be recommended talking about a 1500 dollar decision!
Old 11-19-2010, 08:51 AM   #11
2010 SS RS
2010 SS RS's Avatar
Yeah but money so well spent..Lingenfelter or ADM come with a new controller and require rewiring harness but they both work very very well. my 89.7lb injectors have a need for fuel and results are good....I have been told that on a twin pump twin BAP's would be needed if you want to boost both pumps....
Old 11-19-2010, 09:43 AM   #12
Stingr69
'69 Owned Since '79
Stingr69's Avatar
Jsharp,
Is that the Z06 pump you speak of? I like the sound of that mod but the price is not cheap. Edelbrock says they advise the Z06 pump over the voltage booster so that makes me think they have reason (reliabillity) to prefer it.
-Mark.
Old 11-19-2010, 10:28 AM   #13
jsharp
jsharp's Avatar
No KB BAP is what they are saying will work fine. Others say go with intank setup
Old 11-20-2010, 07:13 AM   #14
2010 SS RS
2010 SS RS's Avatar
Lingenfelter twin pump uses two CTSV cadillac pumps..Very nice set up and right at 1000.00 but also includes a new controller. ADM is the same set up.
all parts for complete install included. Installation requires the dropping of the tank which is a pain in the ass..But well worth it and will allow for your future upgrades. If you want to use a BAP on top of system you will need two. Voltage of a single BAP is not sufficient for two pumps. Same was found with stock controller..Not sufficient for twin pumps!k This single item proved to be one of the hardest to really get our arms around. So many different perspectives. In addition, the tuning software was showing positive results from BAP units but when checking readings for voltage after the stock controller it was found that the boost voltage was not getting thru. so the false positve readings was giving us a false sense of security....Take a manual pressure reading off the fuel rail..dont rely on the reading of the obdII system...Just sayin!
Buying a use KB boost a pump Supercharged SS Forced Induction - V8 2 08-29-2010 01:47 AM
Lingenfelter 2010-2011 Camaro fuel pump voltage booster kit jrh@lpe Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 0 08-28-2010 01:24 PM
Maggie Boost a Pump Question YLWJKT Forced Induction - V8 4 06-16-2010 12:09 AM
Final Word: ALL Stripes Factory Installed? Embalmer Cosmetics and Lighting Modification Discussions 14 03-09-2009 07:44 PM
Good Woork. headpunter 5th Gen Camaro SS LS LT General Discussions 23 01-12-2009 02:25 AM
