11-18-2010, 09:32 PM | #1 |
Suspension mods for the best M6 60' times
I ran a 11.200 with a 1.735 60' time on MT drag radials. My trap speed is around 119 MPH. The driveability of my M6 car is great at this point and I would like to keep it that way as much as possible. While this is pretty good for my setup I would like to try to get into the 10s without increasing my boost which is only 5.5psi. I think if I can get a 1.6x I will be in the 10s or pretty darn close. Getting this car in the 10s with DRs without more boost or meth is a challenge for me. What are the best suspension mods and what improvements could I get with these?
LPE 417 - TVS2300 787 RWHP 759 Torque - Built by WWW.KYSPEED.COM
11-18-2010, 09:38 PM | #2 |
Back on the dino-juice
Drives: '10 LS + a few more Join Date: May 2010
So, you're cutting this with stock trailing arms, springs, rear suspension?
I wake up in the morning and I piss excellence.
-Ricky Bobby America is all about speed. Hot, nasty, badass speed. -Eleanor Roosevelt, 1936 |
11-19-2010, 12:17 AM | #3 |
get some trailing arms in there... grab a two step from lingenfelter and i would say get actually drag racing tires.... drag radials in a manual are not the best choice once u start getting more and more power.
85 Buick TType - 5.3l GT4202r 10.86 at 126
11-19-2010, 05:34 AM | #4 |
Nope, I haven't done any suspension mods so far.
11-19-2010, 05:47 AM | #5 | |
RTCTTFMF
11-19-2010, 08:17 AM | #6 |
Drives: Race Car Join Date: Sep 2009
I would at least start with trailing arms and then look at toe rods. I would also eventually work my way into doing some bushings, especially the rear cradle and differential bushings. Those 4 items will really get you setup for what you are doing. If you are going to stick with a 18" drag radial I would stick with Mickey Thompsons. We use a set of M/T 305/45/18 on a set of 18" C5 Z06 rims and we have done very well. If there is anything I can help you out with let me know.
11-19-2010, 08:31 AM | #7 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
Have to agree. The suspension is critical when your getting to this point. BMR did great with the Gen 4 F-bodies and then the GTO's. They are not far from a few dragstrips and do their R&D on the track. The more power you have, the harder to get it to the ground properly.
11-19-2010, 08:29 PM | #8 | |
11-23-2010, 09:07 AM | #9 | |
Drives: 2010 1SS Join Date: Jan 2010
The polyurethane we use in our TCA026 trailing arm bushings is formulated from 95 durometer urethane. This is a very low deflection bushing that has been proven to perform and last on the street and track. It is also internally fluted with grease channels that allow you to pump grease to every portion of the bushing through one fitting. You will be more than fine using this part number for street/strip use. |
11-23-2010, 02:59 PM | #10 |
Drives: 2010 camaro Join Date: Aug 2009
just curious , how do you launch..great times on 5.5 boost and no suspension mods....turn everything off? hold down button for 7 seconds? also what rpms do you launch from...ride the clutch out ? thanks .thanks for some imput
11-23-2010, 09:01 PM | #11 |
Yea 1.73 not bad on drag radials 20" rims.
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
11-23-2010, 10:49 PM | #12 | |
Drives: 2010 camaro 2ss/rs blk/wht stripes Join Date: Oct 2010
11-24-2010, 05:46 AM | #13 |
Yes I am turning everything off, press the TC button once let go then press and hold it down again for 7 seconds. I launched at around 4,000 to 4,200 RPMS. I just let the clutch out fairly quick but don't just dump it. I never slip the clutch. Keep in mind I was using MT ET Street radials IIs 305/45/18s and Spohn 1,400 HP axles. I have since added an LPE ZO6 clutch so far I love it, but I have not been back to the track since I installed it.
11-24-2010, 05:48 AM | #14 |
I am using MT ET Street radials IIs 305/45/18s on 18" C^ ZO6 wheels and Spohn 1,400 HP axles. I have since added an LPE ZO6 clutch so far I love it, but I have not been back to the track since I installed it. I am mounting a set of Nitto 555Rs today for my stock rear 20" wheels.
Similar Threads | ||||
Save $$$ with Pfadt suspension packages from Apex Motorsports | Apex Motorsports | Suspension / Chassis / Brakes | 75 | 12-13-2010 09:29 AM |
Newest Camaro Ugrade at a Seriously Knowledgable Pedders Suspension Export in Mt. Vie | Info@PeddersUSA.com | Suspension / Brakes / Chassis | 8 | 04-21-2010 11:15 PM |
Pedders suspension already for the Camaro | Info@PeddersUSA.com | Suspension / Brakes / Chassis | 75 | 10-21-2009 07:25 PM |
The BEST of times in the worst of times | ctk1 | 5th Gen Camaro SS LS LT General Discussions | 7 | 03-06-2009 11:36 AM |
Bose Suspension... I want | CamaroSpike23 | Wheels and Tires Talk Sponsored by The Tire Rack | 15 | 03-04-2008 09:38 AM |
