11-24-2010, 06:27 PM | #1 |
Drives: Escalade EXT - Was a 2010 Camaro Join Date: Nov 2009
Headlights
I have a non rs. What is the best replacement bulb anyone has used?
Does anyone know what I can do to darken the headlights like the rs lights are?
Shake N' Bake |
11-28-2010, 12:34 AM | #2 |
anyone wanna help me with suggestions...?
Shake N' Bake |
11-28-2010, 01:11 AM | #3 |
Are you looking for halogen or hid? There a few few companies that make them. You need a H13 hi/low bulb. As far as darkening you lights check here http://www.headlightarmor.com/10-11-...ting-kits.aspx
11-29-2010, 05:12 PM | #4 |
Drives: 2016 Camaro 2ss Join Date: Aug 2010
wouldn't these reduce visibility at night? I want to do the same to my headlights but I'm afraid of losing visibility.
11-29-2010, 05:59 PM | #5 |
Drives: Company Car Join Date: Sep 2009
Yes any smoked headlight kit will reduce light output. With our lightest smoked headlight kit the actual loss is less than you might think. Given the recessed nature of the headlights all levels are going to look a little darker than they otherwise would given that they are going to 'in the shade' during the day - partially covered from above by the bumper cover.
Light Smoke Headlight Protection Kit (signals not smoked) |
11-30-2010, 09:03 AM | #6 |
Drives: 2011 Camaro 2LT Black w/ Wh Rallys Join Date: Nov 2010
That is unless you put in projectors... there's a DIY kit for doing this out now...
Q: "What is a Camaro?"
A: "a small, vicious animal that eats Mustangs." ~ circa 1967 "ROAD RAGE" ~circa 2010 |
11-30-2010, 05:58 PM | #7 | |
Drives: '10 Camaro LS - M6 Join Date: Mar 2010
http://cgi.ebay.com/ebaymotors/2010-...ht_6587wt_1165
11-30-2010, 06:58 PM | #8 |
Just an option
He asked about the black, and unless you put in projectors, it will mess with the lighting output, like you stated. But, as stated above, there are other options besides a DIY... but they are more expensive.
11-30-2010, 07:41 PM | #9 |
Drives: '69 SS Convertible Join Date: May 2009
If you can spend the extra money then go with some HID with projectors. You'll probably have $500-$600 depending on what you want to do. I'll be posting some more info on what I'm doing in a month or so.
At very least I would tell you to do a HID kit from someone like BfXenon, Flashtech, or AAC. You'll have about $250 in that but it's and easy install and you can switch back to factory Halogens easily. I have a DIY out there on it. However, the projectors are ultimately going to be better. It's just all in the amount of money you want to spend. I might have my AAC HID kit up for sale soon because I'm going to upgrade to projectors. PM if your intrested in a deal on one.
Build Journal |
11-30-2010, 08:59 PM | #10 |
Drives: 2016 2SS, SW Join Date: Oct 2009
I've seen conflicting pictures of the color of those HOD's.
I bought Putco Nitro Blue (230013NB) bulbs and they are damn close to my new LED fogs. |
12-01-2010, 10:00 AM | #11 |
Mark it ZERO!
They're calling crappy blue overheating bulbs "h.o.d's" now? I guess improvements have been made...
12-01-2010, 12:11 PM | #12 |
Thanks for all the help. What goes into making mine the projectors (time,money, and parts wise)? I know that's what I really want to do, but it sounds more like something I would feel more comfortable having other people install for me.
But the upgrade to HID is probably more along what I want. What goes into that? I think it's something I could do myself from the little I know about it.
Shake N' Bake |
12-01-2010, 12:41 PM | #13 | |
12-01-2010, 01:32 PM | #14 | |
1) change light bulb 2) change bulb and add a few wires/box 3) remove bumper and replace whole headlight fitting (am i missing anything?) 4) Don't know / don't care 5) No way i'm going that far
Shake N' Bake |
Similar Threads | ||||
2010 CHEVY CAMARO PROJECTOR HEADLIGHTS | CARiD | Exterior Parts & Accessories | 4 | 08-11-2010 01:50 AM |
Has anyone bought Oracle Headlights?? I have questions!! | ihaveacamaro | Cosmetics and Lighting Modification Discussions | 22 | 06-09-2010 08:04 PM |
Do our headlights come on with our wipers? | wrek | 5th Gen Camaro SS LS LT General Discussions | 10 | 10-23-2009 04:30 PM |
Swap RS headlights with non RS headlights | rallyyellow | Cosmetics and Lighting Modification Discussions | 14 | 10-09-2009 04:49 PM |
Condensation in late 4th gen headlights? | MAC | 4th Generation Camaros | 27 | 06-30-2008 01:53 PM |
