12-09-2010, 09:51 AM | #1 |
Magnacharger Rear Cog Drive is the BOMB!
Recent testing proved that at higher boost levels the cog drive is an excellent investment.
On superchargedSS car the with the standard 10 Rib Rear Drive the boost would start at 12.5 and drop to 10 psi at peak RPM, everyone asked where the boost was going and we attributed it to the big blower cam we use. We recently just installed the VERY FIRST Magancharger Rear Cog Drive and I am On the Dyno with it. Now the Boost Starts at 12.5 Drops to 11.5 at Peak Torque As expected but then climbs back up to 12.5 at Peak RPM. This will be worth some extra power as I progress through the tune, I started by taking out timing to be safe and dail in the AFR to match the Boost Curve and I am already seeing More power at Peak RPM. It was Real Nice Surprise since the Only Reason we Thought we were installing it was for the COOL NOISE it makes. Ted.
www.jannettyracing.com
12-09-2010, 09:54 AM | #2 |
Drives: Anything Blown Join Date: Aug 2010
That is great news!!
THANKS!! |
12-09-2010, 09:55 AM | #3 |
Drives: 1999 Trans Am Join Date: Jul 2009
Makes sence when you look at the belt wrap on the 10rib rear drive.I just ordered the cog setup for a customer -more towards the noise though.
12-09-2010, 10:01 AM | #4 |
Drives: 2x 05 Vettes/65'AC cobra/68 camaro Join Date: Apr 2009
yea at higher boost it works great! and the noise is o so cool!!!!!!!!!!
12-09-2010, 10:19 AM | #5 |
There is nothing better than having that loud whine under the hood, I really hope my Camaro will be making a trip back to you Ted for the Magnacharger with the cog,
12-09-2010, 10:37 AM | #6 |
Drives: 2010 Camaro Join Date: Feb 2010
I still wanted it for the whine! I hope your posting this from inside my car while on the dyno!! I checked, it's at least 20 degrees out by now. Do you need me to get you a snuggle for Xmas so you can tune in the cold!
12-09-2010, 10:43 AM | #7 |
You can just Lend me your Favorite Pink One
12-09-2010, 10:46 AM | #8 |
100% Chevy & Harley Man
Drives: 2010 2SS: Blown LSX 376-B15 Join Date: Feb 2009
So re-tuning is needed?
LSX 376-B15, TVS2300 SC, Harland Sharp Rockers w/ Trunion Bearings, ATI Balancer/keyed, AR LT Headers/Borla Catback Exhaust, DSS 1400 HP Axles, DSS aluminum driveshaft, 3.70, Hotchkis Springs/Sway bars, Forgeline SO3P Aluminum Wheels (20x9.5 F/20x11 R)w/ Hidden Titanium Hardware, Nitto NT05 Tires (27540ZR20 F/31535ZR20 R), Billet LPE brake/gas pedals, Escort 9500ci Radar Detector Laser Jammer, Roto Fab CAI with Ice Silver box, Carbon fiber tube/MAF Housing Assy, LPE Aluminum coil covers, SS9 Sleeper Fiber Glass Hood (ACS), Carbotech 1521 ceramic brake pads, Elite catch can.
12-09-2010, 10:56 AM | #9 |
If you are just doing the rear pulley swap there is no retuning needed, unless you are running >10lbs of boost maybe.
I am sure one of the shops can chime in if I am wrong... but if running at 6-8lbs of boost there should not be any rear belt slippage. |
12-09-2010, 10:56 AM | #10 |
12-09-2010, 10:59 AM | #11 |
It could since you will be moving more air from mid to top RPM that was not there before.
It should at least be checked with a Wide band and datalog. Again this will only show up on Higher Boost Applications. This car is equipped with a 10% overdrive Crank Pulley, 3.2 upper pulley which on a stock engine would produce about 16 PSI. This engine has our Smooth Idle Blower Cam, 2 inch headers, and 3 inch exhaust with no kittens so even though boost is only 12.5 the blower speed is up there. Ted.
12-09-2010, 11:29 AM | #12 | |
12-09-2010, 11:39 AM | #13 |
Yup, I would make sure your numbers are good in the mid and higher ranges.
It is possible you will gain some ponies (I missed the forged & tuned right part of your sig earlier!) |
12-09-2010, 11:46 AM | #14 | |
Must be hormonal!!! Or because I just changed it!! I noticed the pic size was cutting off the words so I just made it simple!.
Similar Threads | ||||
CAMARO WIKI | Tran | Wiki | 66 | 04-22-2024 11:41 AM |
Anybody miss old school rear drive wagons? | Dave McFly | General Automotive + Other Cars Discussion | 25 | 08-29-2009 09:13 AM |
Zeta (Camaro/Commodore/G8) suspension details | Gatecrasher | Wheels and Tires Talk Sponsored by The Tire Rack | 66 | 04-16-2009 01:11 PM |
Popular Mechanics has their drive | radz28 | 5th Gen Camaro SS LS LT General Discussions | 42 | 08-29-2008 04:51 PM |
GM Rationalizes Rear Drive | Mr. Wyndham | 5th Gen Camaro SS LS LT General Discussions | 41 | 05-12-2008 07:57 PM |
