#29 |
Drives: own more cars than i can list Join Date: Nov 2010
CV shaft
![]() We have released the aluminum shaft for purchase, here is a link to the listing and the text from it. http://www.driveshaftshop.com/domest...ece-driveshaft Available now for the 2010+ Camaro is our 3-1/2 aluminum shaft with CV . We have done extensive testing with stock rears and with our 9" kit and believe this to the the most cost effective trouble free drive shaft for the Camaro available today. The shaft will come with our signature billet plates for each end so you done have to go in to the rear taking a chance on upsetting the crush collar (see below for billet plate VS changing to a Pinion yoke below) The shaft only weighs 17lbs and come with special 12.9 uber strength hardware with back up lock nuts to ensure no loose bolts, we have been using this Billet aluminum style plate for over 10 years on thousands of 1000+Hp Supras-BMW's and many more with out any bolt issues. (You will have to remove the heat shield from above center hanger mount to install a 3-1/2" shaft ) Last edited by Driveshaftshop; 12-22-2010 at 06:57 PM. |
#30 |
![]() Drives: Jeep srt8 Join Date: Nov 2009
my camaro is pretty stock u r seeing my jeep mods lol.
2010 2ss/rs inferno orange with inferno interior with painted body kit.
MODS 20% tint, Borla Atak, BBK Headers no cats, Cold air induction cai, custom tune. 2007 JEEP SRT8 11 Second club V-3 Vortech Supercharger, Borla S, 180 t-stat, diablo sport predator, Eibach lowering springs, shorty antenna, crossed drilled and slotted rotors, dash hawk, 20% tint,tinted tails, rammedic23 fiberglass hood. |
#31 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 10 LS3 2SSRS IOM,21 ZLE Wild Cherry Join Date: Aug 2009
Any part #s for McMaster bolts? IPS mentioned McMaster bolts before, but nobody could find what was used, so gave up trying.
860 RWHP 924 RWTQ,TVS2300 10/14 OD 2.75/NW 102mm,RDS/FLOWED "109" SHOT/LPE NCC NLP spoiler/GM splitter/Torq HE-fans/oil coolers/IC1000cc Squash twins,GT9,Coil Covers,Mats,Pedals/ADM Gauges,Race Scoop/Trunions DDS CVs,Carbon F DS/RPM L6/LPE 9.5 3.73/Pedders HD bushes,align kit RB 2-piece rotors,S/S Lines,Hawk HPE Pads/Forgeline SP3P/Weld RTS Ceramic ARH 2" LT/3" X-pipe,Corsa Touring/BMR TA,Toe,LCA,DS Loop StreetSlayer BC3/MTI Shifter-Trans mt/Hotchkis CB/Monster CC/SJM LineLock PFADT Coil Overs,Sways,Links,Mounts,SF Bushes,Camber Kit LPE Brotherhood . |
#32 |
Sold as soon as produced - I can think of several people that will be doing the same. Any ETA?
#33 |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
i was driving one day july last year. I was playing around with another car and once i resumed back to normal driving, i felt a drivetrain vibration. Took it to the dealer the next morning and he said that my tires were bald and as a result, went out of rouund. So i forked out $430 to buy 2 brand new pirellis from a buddy of mine that works at a tire station. Identical model and size as the factory 20s. Slapped them on, still had the vibration. Took it to the dealer again and then they told me that they couldnt find anything wrong with it. Told me to drive it like that and to come back if it got worse. I told him I would not take the car until the vibration was fixed. So i left it there and 3 hours later, the service manager calls me. Said the driveshaft had bolts missing. They ordered a complete new set, and the car has been good as new ever since. Reading all your stories here, im glad I refused to take my car out of that dealer till it was fixed
Bone Stock |
#34 |
Boost Is Your Friend
Drives: 2016 Hyper Blue 1SS Camaro Join Date: Oct 2008
part # on stock bolts?
#35 |
![]() ![]() Drives: Everywhere Join Date: Jun 2008
Prop to coupler:
Bolt-92228335 (x6) Washer-92228334 (x6) Nut-92228333 (x6) Coupler to diff yoke: Bolt-92139104 (x3) Coupler to trans yoke: Bolt-92138569 (x3) Nut-90538867 (x3) Last edited by Robert91RS; 01-25-2011 at 09:05 AM. |
#36 |
Emerald Coast Camaro's
#37 |
Drag Racer
Drives: 2010 2SS/Rs Join Date: Dec 2010
idid it myelf n replaced wih stroner bolts i hunted down. it happened to me twice as well...\
#38 |
Banned
Drives: 1991 New Yorker, 69 Tbird, ABM2SSRS Join Date: May 2009
Same problem, same parts taken out. But my flowmasters survived due to me shutting down quick. Fixed, dealer offering to get me a rear tunnel brace.
#39 |
Drag Racer
bent my borla. and pulled a tab that put two pin holes i my exhaust.
damage the heat shield the shield is attached to the gas tank by a glue. its a ****ed up design im pissed it did this and i payed 39K for my car....i love my car but DAMN. theres one thing ill finally admit ford does a better job. design. production. and engineering. its fun becuase Gm has kept this on a hush all of a sudden everyone is comin out saying the same problem...one of the MAJOR probles is that the rear yoke has thre bolts but they get loose too easy. ONE THING ID LIKE TO ADD.. WHEN EVER LEAVE ON A CONTROLLED LAUNCH WITH JUST T/C OF..ITS FINE.WHEN I TRIED TO DUMP WITH COMPETETIVE MODE ON IT WHEN IT BROKE IT.. IF YOU DONT WNT TO BREAK ANYTHING DONT DUMP YOUR CLUTCH HARD, EVEN ON STOCK TIRES. UPGRADE FIRST OR AFTER EVERY TRACK VISIT CHECK YOUR BOLTS. I RECCOMEND CHANGING TO A STRONGER BOLT PERIOD. AND USING LOCTITE. LOTS OF IT |
#40 |
In The Circle
Drives: 2010 Camaro 2SSRS IOM M6 Join Date: May 2009
That's exactley why a put a Driveshaft Shop one piece in Pumpkin. No regrets and piece of mind to know that it's all good now.
#41 |
![]() Drives: 2010 Camaro 2SS LS3 6 speed IOM/IOM Join Date: Apr 2010
Glad to see you got it back!
#42 |
'69 Owned Since '79
Drives: '69 Z/28 LeMans Blue w/White Join Date: Oct 2008
Broke a driveshaft bolt yesterday. None of the local GM dealers stock these fasteners. You have to believe they are reusing the bolts in service.
![]() I will order some replacements to install myself and see if they will hold up better. -Mark. |
Thread Tools | |
