01-15-2011, 08:03 AM | #1 |
Philippians 4:13
Drives: SLP Supercharged LS3 Join Date: Aug 2009
Those with the GM Fuel Door... How to Remove?
Hey guys, I have a questiion for those of you that have the GM fuel door as seen below. I like the door, but it is not going to fit the theme of my car anymore. I just put on some gun metal colored TSW wheels. Anyways, I want to reinstall my factory door. When I installed the billet one, it came with a small pish pin to lock in the door so it would not fall off. My question is this... How do you get the pin out for removing the door? The pin once insert sits flush with the surface. Help please.
Has anyone else had this problem or removed one of these? Thanks [IMG][/IMG]
01-15-2011, 08:08 AM | #2 |
Very small drill bit or maybe an exacto knife.
Mods: BBK Intake, BBK LT's and High Flow Cats, Corsa Cat-back exhaust, Hurst short throw shifter, SLP skip-shift eliminator. 7/1/09 Placed order for IOM/IO int/ SS/RS 6M 9/26/09 Took delivery! |
01-15-2011, 08:13 AM | #3 |
Philippians 4:13
OK, I'll give that a try. Anyone else just in case this does not work?
Thanks
01-15-2011, 08:16 AM | #4 |
Might want to PM Ssooch I think he had one that he took off. He might be of more help.
01-15-2011, 09:59 AM | #5 |
Drives: 2SS LS3 Join Date: May 2010
It's not supposed to be easy, to prevent theft. I tried to remove mine once and gave up.
2010 CGM 2SS LS3, born: 4/10 |
01-15-2011, 02:18 PM | #6 |
Philippians 4:13
No luck with drill bit, anymore ideas?
01-15-2011, 04:11 PM | #7 |
Rollin' Green
Drives: 2010 Synergy Green Camaro Join Date: Dec 2010
You could try a punch tool.
07-23-2011, 06:54 PM | #8 |
Drives: 2011 Camaro 1SS/RS Join Date: May 2011
I'm having same problem. Any ideas? I want to put my stock fuel door back on.
07-23-2011, 08:11 PM | #9 |
dont really know how to remove, but if your interested in getting ride of it, once removed of course, i'll be happy to take it off your hands
07-23-2011, 08:17 PM | #10 |
sure it's a push pin and not a set screw? Mine never had one(just held by the clip), so going from one to the other is no biggie...
07-23-2011, 08:28 PM | #11 |
I'm assuming that there's no extra hardware on that fuel door and it just pops on in place of the stock one, and the stock one just pops right off. If you open the door and pull it straight towards you it'll just slip off. I just did it and dropped mine on my garage floor...sigh. If it has extra hardware it can't be that hard to take apart.
07-23-2011, 08:48 PM | #12 |
Philippians 4:13
I did finally get mine off with a small long drill bit that was the same size as the pin. I just slowly ran the drill until I bore out the pin and then the door came right off.
07-24-2011, 07:41 PM | #13 |
Got it off but the retaining tabs on the door broke. Got my stock one back on so I am happy.
07-24-2011, 08:34 PM | #14 |
Philippians 4:13
Yep, I am much happier with the stock one back on too. The whole fuel door thing just does not work with these cars in my opinion. I do like them on some cars like the Mustangs, but I almost think it ruins the body lines on the Camaro because it is so bulky. Had it looked like the concept It would be a different story.
Similar Threads | ||||
Pfadt Race Engineering DIY Drop Spring installation procedure | PfadtRacing | Suspension / Chassis / Brakes | 20 | 09-23-2011 09:31 PM |
How many people will E-85 their new camaro? | Speed74SS | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 57 | 01-03-2011 02:16 PM |
Lingenfelter 2010-2011 Camaro fuel pump voltage booster kit | jrh@lpe | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 0 | 08-28-2010 12:24 PM |
Why i think you cant do a Dyno in the same day | 2SSRS@Gen5diy | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 123 | 10-22-2009 07:37 PM |
Camaro ls3 news...true or false? | Dark Knight | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 74 | 06-05-2008 05:29 PM |
