01-15-2011, 12:17 PM | #1 |
Drives: 2010 2LT/RS Join Date: Jan 2011
2010 camaro USB don't work
i put 3 different flash drive on my usb port 1 sandisk 4 GB and 2 kingstone...nothing appens..on the radio display can't change source to usb port only appear "aux jack input".
flash drives leds don't go on and radio seems don't read them. all flash drive are FAT32 formatted and work on PC..all songs (100) are mp3. what can i do?? |
01-15-2011, 12:18 PM | #2 |
Drives: 2014 Sonic, 2010 Camaro SS Join Date: Jan 2009
Sounds like the port is not connected to the radio. Take it to the dealer.
01-15-2011, 12:27 PM | #3 |
Drives: 2010 2LT / RS - 2013 ZL1 Join Date: Aug 2010
I think the problem is that your using FAT32 format. Think you should try NTFS formatted USB, I have a feeling that will work. Had the same problem with game consoles, none would read FAT32 format. Only used IPhone for my Camaro's USB port without a problem.
01-15-2011, 12:37 PM | #4 |
Psssssssssshhhhhhhhhhhhh!
Drives: under contruction Join Date: Nov 2009
Several people have reported having a problem with the USB port.
Mine quit recongnizing my ipod after the first month I owned the car. They replaced the PDIM module under warranty and it has worked fine ever since. |
01-15-2011, 01:31 PM | #5 | |
Mine is formatted in FAT32. Not problems reading the drive. I do think I have the radio display going blank figured out. That has more to do with the file names though. Rather than file system.
01-15-2011, 01:46 PM | #6 |
Drives: 2010 Camro 2SS Join Date: Apr 2010
You must use the usb port for MP3 player not for flash or zip drive. It doesn't work because they are not a player, just mass storage device.
01-15-2011, 01:47 PM | #7 |
01-15-2011, 01:50 PM | #8 |
Mine has never worked this way I guess that I need to carry mine back also. The display just reads not recognized.
01-15-2011, 01:57 PM | #9 |
Don't Like it? Suggit.
If you say it with enough confidence, perhaps it will be true!
"Tops off, tach up baby- loud and proud!" A Camaro lover from day one- 1996 3.8 V6 Camaro, to 1996 5.7 LT1 Camaro Z28, to the sold 2002 5.7 LS1 Camaro SS, and NOW, a [I]6.2 L99 VR 2SS/RS: XS Power stainless full exhaust, Airaid CAI, BMR drop springs and sways, custom tune by Cal Speed- 411rwhp |
01-15-2011, 01:59 PM | #10 |
I suggest you read the manual to make sure your flash drive is formatted properly and that you are using file type (mp3) and file structure recognized by the pdim. If it is and it still doesn't work, then you need to take it in to the dealer.
01-15-2011, 02:00 PM | #11 |
one time i tried inserting my USB stick in port by force thinkin' its the right way in.. but i had it the wrong-way round, you guessed it.. i broke the built in port!! now i cant charge my BB when i need it and have no time to go to the nearest dealer to fix it!
01-15-2011, 02:56 PM | #12 |
Ok what is the correct format. I have tried NTFS, FAT32,and exFAT none are recognized. All songs are MP3 format.
01-15-2011, 03:10 PM | #13 |
In the root directory of the drive?
01-17-2011, 02:36 AM | #14 |
me too...tried fat32 and ntfs..files in the root directory..all mp3...
Similar Threads | ||||
CAMARO WIKI | Tran | Wiki | 66 | 04-22-2024 11:41 AM |
New Camaro Exterior and Interior Stainless Steel Trim Parts from RPI Designs! | RPI Designs | Exterior Parts & Accessories | 30 | 02-20-2013 03:23 PM |
Camaro Product Manager - interview | Moose | 5th Gen Camaro SS LS LT General Discussions | 11 | 04-04-2012 06:10 PM |
PWA "The Lounge" | DGthe3 | Off-topic Discussions | 143773 | 11-06-2010 11:00 AM |
