01-28-2011, 09:10 PM | #1 |
Drives: 2010 Camaro 2SS/RS Join Date: Aug 2010
5th Gen DIY Turbo Build
Hey Guys,
I started my turbo build today and wanted to share a few pictures. This is the first of many updates I'll be doing, so make sure to check back if you're interested in this type of project. After some planning, I've decided to do a single rear mounted turbo - mainly because I haven't seen one on a 5th Gen and I'm attempting something a little different. I built a similar kit for a cammed LS2 GTO and it ran a 10.1 at sealevel, so I'm hoping for decent results at this altitude (6000ft). I'll be using a Turbonetics BB T76 .81 A/R using 2.5 pipe intermediary pipe. If I did my math correctly, the 42psi of back pressure the LS3 creates and the 2to1 merge into a 2.5", I should see full boost around 3100rpm - which I can totally live with. Since I didn't want to completely fabricate new intermediary pipes, I searched around for a stock H-Pipe setup. My new best friend Larry (2010 SS RS) graciously donated his stocker to me so I could do this build. Thanks again Larry! So this is what I started out with. Just a plain Jane exhaust system off of a 2010 SS. The first step is to brace the two pipes together. There's A LOT of cutting involved and the most important thing to do is keep the pipes perfectly separated so that everything will line up with the manifolds once it's ready to be installed. I just used to some extra 1/4" flat stock I had laying around. Nothing fancy. Next came the cutting. I made the cut approximately 9" from the first 90* bend and continued down through the intermediary plate (H-Pipe). The trick is to remove enough pipe so that the merge will connect where the old H-Pipe was. We'll get to the actual fabrication of the merge further down the thread. After the initial cut was made, I had to remove the stock H-Pipe section. It was faster to make a new section and notch it for a merge than using the existing H-Pipe hole. So the first step was to remove the old section. Remember the other side of the exhaust that I removed? Well I reused some of the straight pipe to make my new section (I'm big into recycling scrap).
"This house is protected by the good Lord and a gun. You'll meet both if you show up uninvited."
01-28-2011, 09:17 PM | #2 |
Before I cut into my main exhaust, I made sure to mark the pipe with a Sharpie so I can make sure everything lines up before I weld it.
Then I made the "real" cut. Before I started to tack weld the pieces in place, I made sure to level the tubing faces to ensure that the pipes sat flush. Then I started to tack Before making the final welds, I made sure the piping was lined up and level.
01-28-2011, 09:24 PM | #3 |
Next came creating the merge pipe. I had some extra 2.5" exhaust bends from my old Corvette, so I cleaned them up and began cutting.
I forgot to take a picture of the hole cutting process, but basically I used a 2 1/8" bi-metal hole saw and then a die-grinder to enlarge the hole. The picture below shows the merge pipe "mouth" tack welded in. After measuring the distance between the two pipes, I used some extra scrap from the other side of the exhaust and joined the two pipes together. After doing the final welds, I cut off the bracing and the hardest part of the build was done. Next week I'll be posting the positioning of the T4 flange, removing the resonator and cutting/fitting the Wastgate pipe. Stay tuned! Vince
01-28-2011, 09:32 PM | #4 | |
Prefer to be blown!
Drives: 2010 Silver/Black 2SS/RS Manual Join Date: Mar 2010
http://www.camaro5.com/forums/showthread.php?t=38022
MagnaCharger TVS-2300 550rwhp 540 rwt and a radical suspension under the car.
01-28-2011, 09:35 PM | #5 | |
Very nice, but it's not a SINGLE rear mounted turbo... Unless I'm missing something.
01-28-2011, 09:47 PM | #6 |
Prefer to be blown!
You are not missing anything, just wasn't sure if you saw the dual setup. Good luck with your build, I'm subscribed!
01-28-2011, 09:52 PM | #7 | |
01-30-2011, 09:35 AM | #8 |
So after some interesting feedback I received on another board, I'm going to redo my merge pipe. Apparently I used too many transitional bends that would could turbulance and inhibit the flow; so I'm going to rebrace the pipes and do something like this. Don't mind my awesome MS Paint skills....lol
01-30-2011, 10:22 AM | #9 |
Drives: everyone crazy... Join Date: May 2009
01-30-2011, 10:40 AM | #10 |
Pretty much....I actually named my rifle St. Peter because that's who will greet you before the pearly gates.... My attempt at levity
01-30-2011, 10:44 AM | #11 |
Whipped
looks neat. . . can't wait to see the end product.
01-30-2011, 12:04 PM | #12 |
Prefer to be blown!
01-30-2011, 12:05 PM | #13 |
Drives: 2SS/RS Join Date: Apr 2010
Very interesting. Something different. Looking forward seeing the end result.
01-30-2011, 12:05 PM | #14 |
Prefer to be blown!
Similar Threads | ||||
Granatelli / Turbo Tech Twin Bottom Mount Turbo Systems | Granatelli | Forced Induction | 20 | 11-30-2010 06:47 PM |
How much is the STS single turbo? | HarrisraTx | Forced Induction - V6 | 70 | 10-21-2010 08:37 PM |
TTP Single Turbo 62/76/88mm Kits - In-House Installations | Sales @ ECS | USA - NY / NJ / PA | 4 | 03-03-2010 09:42 PM |
FrankTs Ultimate Performance single turbo Camaro SS 602whp/613wtq | JTinFL | Forced Induction - V8 | 17 | 10-13-2009 03:03 PM |
Lawdogg149's Ultimate Performance single turbo Camaro SS 610whp/630wtq | JTinFL | Forced Induction - V8 | 25 | 10-06-2009 07:25 PM |
