Old 03-09-2011, 09:17 AM   #1
fldrummer
"Black Ace"
fldrummer's Avatar
Drives: Supercharged 2010 SS, 2016 Golf R
Header install: reuse gaskets a 2nd time?
I'm switching to long-tube headers tomorrow and have already reused my stock gaskets once when I installed my shorties (back when I had only a few thousand miles on the car; I have 30K now). Do you think I'll be okay reusing the stock gaskets again or should I get a new pair? If going new, does anyone know where I can get new ones and what types to avoid? Thanks for any input.
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged 416 LS3, Maggie TVS 2300 SC (~11 psi), custom cam (232/247, .630/.630, 118 LSA), 90-lb. injectors, ZL1 fuel pump & ADM controller, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Kraftworks. 755 rwhp/708 rwtq
fldrummer is offline   Reply With Quote
Old 03-09-2011, 11:00 AM   #2
tman52804
tman52804's Avatar
Drives: 2010 Chevy Camaro SS/RS
What material are the factory gaskets? Copper, etc?
2010 2SS/RS
3" MagnaflowComp Series Exhaust
Airaid CAI
MGW Short throw shifter
Kooks LT Headers/Hi flow Cats
Vmax TB
tman52804 is offline   Reply With Quote
Old 03-09-2011, 11:11 AM   #3
Oxtar41
Oxtar41's Avatar
Drives: 700 rwhp 2010 SS
Just spend the few bucks and get new ones, Dont want to be installing headers a third time because of a gasket that leaks. Just my .02.
Oxtar41 is offline   Reply With Quote
Old 03-09-2011, 11:16 AM   #4
2010 2-Tone
Drives: 2010 RY 2SS with Custom Stripes
Absolutely go to the dealer and buy factory gaskets. From everything that I have read and done they are the best.
2010 2-Tone is offline   Reply With Quote
Old 03-09-2011, 11:32 AM   #5
boat rx
Drives: 2010 2ssrs
get a hold of me.I have a new set you can have.
boat rx is offline   Reply With Quote
Old 03-09-2011, 01:03 PM   #6
fldrummer
"Black Ace"
fldrummer's Avatar
Thanks. I decided to do just that. 'Just got back from the stealership w/ a new set. A bit pricey for a couple pieces of metal, but if it saves me from having to re-install the headers down the road or, worse yet, get stuck w/ a leak during install, I guess it's worth it.
Old 03-09-2011, 01:06 PM   #7
fldrummer
"Black Ace"
fldrummer's Avatar
Darn; 'wish I would've posted this earlier. I was just down in Miami last night! Oh well!
Old 03-09-2011, 03:02 PM   #8
Sack Rat 2SS
Sack Rat 2SS's Avatar
Drives: Silver SS/RS, Man 6
You might also take a large flat file and file lengthwise down the header flange to aid you in determing if the flanges are flat and not warped. If warped no gasket will prevent leakage. Good Luck
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers,
GM 3.91 Rear Gears
Sack Rat 2SS is offline   Reply With Quote
Old 03-09-2011, 04:13 PM   #9
Alain
Alain's Avatar
Drives: 2016 Challenger Hellcat, 2018 ZL1LE
Yeah the OEM ones are pretty darn good from what I've read and heard. I reused mine when I went to long tubes.
Alain is offline   Reply With Quote
DIY : Install headers on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 70 06-25-2020 06:40 PM
Header install Smoky10 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 10-18-2010 09:47 PM
Dealer Install time for a HURST Shifter? 55Designs V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 2 10-27-2009 04:13 PM
2nd Time at the Paint Shop, only 700 miles 2010 2-Tone 5th Gen Camaro SS LS LT General Discussions 1 10-23-2009 10:01 AM
