05-08-2011, 12:36 PM | #1 |
Drives: Black 2SS/RS M6 Join Date: Mar 2010
LPW Diff Cover
has anyone used the lpw rear diff cover, gm high tech used it on a new gear swap, i would think that it would make a good addition to the jre posi mod with the new main caps. Any thoughts would be great
2010 LS3 2SS/RS M6
AirAid Cold Air Intake, AAC LED sidemarkers, AAC P13w plasmas drl, Kook's Custom 1-7/8" Headers, Corsa Hybrid Exhaust JRE 445 Cam Package, JRE SCT Tune, RX Catch Can and Breather Tech AFX Heater Hose Relocation Kit, Black Chrome Wheels Pfadt trailing and toe arms, Pfadt solid subframe mounts, Pfadt diff bushings, Street Slayer Twin Carbon Technostalgia Camaro LED taillights, CTS-V Front Brakes, Powder Coated Calipers By ME MGW Short Throw Shifter Complete ZL1 Rearend Swap |
05-08-2011, 03:52 PM | #2 |
Cant hurt
05-09-2011, 09:14 PM | #3 |
Tyranny is Closing In
Drives: 2010 Camaro SS Join Date: Apr 2011
05-09-2011, 09:21 PM | #4 |
Drives: 2011 SS/RS LS3 Join Date: Oct 2010
Direct from LPWhttp://www.lpwracing.com/Ultra_IRS/Ultra_IRS.html
05-09-2011, 09:32 PM | #5 | |
05-10-2011, 12:21 AM | #6 |
The main cap studs on the cover will certainly benefit longevity of the diff. Compare to a stock cover, and you can see how this would really help prevent housing flex. For the price, you really can't go wrong
05-10-2011, 10:17 AM | #7 |
Drives: 2010 M6 2SS Join Date: Mar 2011
I've used LPW covers exclusively on my other cars, they're far better than the TA ones...and most other companies are re-badged TA's as well. I've always had good experiences with them.
05-10-2011, 04:05 PM | #8 |
High on "The Camaro Life"
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam Join Date: May 2009
I ordered mine this morning. It will be here tomorrow and I'll post up some pics after the install on Thursday. I talked to Doug at LPW and gave him the measurements of the Jannetty billet bearing caps and he said there should be clearance for them. The billet caps have a nice flat surface for the load bolts to tighten against, instead of the factory rounded caps. The load bolt puts pressure on the Carrier Bearing caps to help keep any flex to a minimum. The end of the load bolt can best be described as the end of the threaded rod on a C clamp that has a swiveling pad on the end of it.
Here's a pic of the Jannetty caps. The circle on each is where the load bolt contacts the cap:
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
05-10-2011, 07:04 PM | #9 | |
2010 LS3 2SS/RS M6
05-11-2011, 12:30 AM | #10 | |
Richmond gears SUCK.... Just my opinion. That's why I will NEVER buy Richmond gears ever again. I'm going with the new LPE AAM 3.91's. They will be here tomorrow!!
05-11-2011, 07:04 AM | #11 |
Drives: Nothing Fun. Join Date: Aug 2009
Ted was talking to me about these covers yesterday, we'll have to call Mark @ LPW and chat about these
Thanks for the suggestion! |
05-11-2011, 06:26 PM | #12 |
Let us know what you and ted think about them.
2010 LS3 2SS/RS M6
05-14-2011, 11:27 PM | #13 |
Rebuilt my diff yesterday with the LPE AAM 3.91's and installed the LPW cover. It is a lot beefier than the stock cover and the load bolts work very nice with the JRE billet caps. The load bolt pads are exactly the same width as the billet caps. I thinks this cover is going to help alot in strengthening the diff. Here are some pics:
I did have to grind down about 2" of the right side of the rib approximately5/16'" deep to clear the frame of the car just above the rear mounting bolt bracket. It fit in alright without grinding it down, but I noticed it was touching the frame, and knew it would make alot of noise transmit through the car. So I pulled it back out and ground some off until I had aprox. 1/8" gap. This pic shows where to grind: This pic shows where I ground the rib. You can see where it would have been touching the frame of the car.
05-14-2011, 11:29 PM | #14 |
Drives: 2010 White SS/RS L99 Join Date: Jun 2010
LPW cover works with the JRE billet caps. Had the posi-mod done with caps yesterday. The JRE billet cap as mentioned provides a nice seat for the covers torque bolts for the bearing caps. Very happy with the outcome.
Similar Threads | ||||
Engine Cover and Manifold Cover for sale | ZZcamaro | Miscellaneous Items | 1 | 12-05-2010 07:19 PM |
aftermarket car cover | 011silver 2SS | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 15 | 11-03-2010 11:23 PM |
Car Cover | domano 68 | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 19 | 05-21-2010 09:51 PM |
SS ENGINE COVER EMBLEM & NAMEPLATE 2010 CAMARO | Kirban Performance | V8 Bolt-Ons & Tunes | 0 | 11-30-2009 01:40 PM |
Putting on car cover alone, possible scratches. | OHIOSS | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 15 | 07-01-2009 09:40 PM |
