07-18-2011, 05:00 PM | #1 |
Drives: Camaro ls Join Date: Jul 2011
Need help with Metra install!!!
Last weekend decided to try and install my metra kit. Now, I have a non ba system and when I installed my metra kit my left front speaker wasn't working. I checked the speaker by putting the stock radio back in and it worked. Need help do I need to upgrade my metra system or what!? Ha thank you
07-18-2011, 05:14 PM | #2 |
Drives: 2011 imperial blue SS, black 92 RS Join Date: Apr 2011
You need to have the module updated. I had the exact same problem.
2011 imperial blue SS/RS a6 12.43@112 vararam, tune, jba cats, magnaflow axle back, self ported tb, under drive pulley, NO headers, Stock tires. 1.87 60ft. Stock tires. SOLD :(
2000 1500 silverado extra cab SOLD :( 2017 Silverado 5.3 all stock 2004 5.7 GTO 78mm turbo |
07-18-2011, 06:02 PM | #3 |
Drives: 2010 Camaro 2LT VR/RS CGM Rally's Join Date: May 2009
where do we get the update?
Email: rdurso1@yahoo.com |
07-18-2011, 07:05 PM | #4 |
Where do I get the update
07-18-2011, 08:17 PM | #5 |
Well I wish that was easy for you. I had to borrow a cable from the audio shop I bought mine from (they didn't know how to do it, and I installed car audio professionally for over a decade...so I was certain I could do it) so anyway, you need the cable, you can get the software update free on the net...I think the name of the company is on the control unit. If not call Metra...they can point you in the right direction. Also, I need to point out that the update plug is inside the box. That right, you have to take the box apart to get to it.
07-18-2011, 08:18 PM | #6 |
If you have no luck, I might be able to make you a cable.
07-19-2011, 12:39 AM | #7 |
Do you think best buy or another electronic installer would be able to update it
07-19-2011, 01:19 AM | #8 |
If I have the ba system will I come across this issue as well? I have my metra kit coming in the mail. About to put in a pioneer avh-4300dvd.
07-19-2011, 03:16 PM | #9 |
Just talked to metra, and I gave them the number that was on the interface. Metra says that my interface is updated so I'm not sure what the problem is from now
07-19-2011, 03:28 PM | #10 |
Drives: Camaro LLT ABM Join Date: Sep 2010
Check all your wires. Sounds like something was not connected right. Its a multiplex system. (If one things wrong, multiple things will not function correctly along with it.) Check your speaker wires off of the harness, make sure everything is connected. Is your A/C working properly?
07-19-2011, 04:10 PM | #11 |
Pink wire connected to the other pink wire?
08-02-2011, 11:04 PM | #12 |
Tried installing it again with metra on the phone and still had the same problem. Anyone have problems with the interface being faulty?
08-22-2011, 01:36 PM | #13 |
Drives: 2011 Chevrolet Camaro Join Date: Dec 2010
yes two of my interfaces have gone bad, make sure you update it!!!! For nwo we have no other choice!
Similar Threads | ||||
DIY : Install headers on 2010 Camaro SS | Nine Ball | Camaro DIY & HOW-TO instructions & discussions | 70 | 06-25-2020 06:40 PM |
DIY Hurst Short Throw Shifter Install - Pix and Video | TAG UR IT | Camaro DIY & HOW-TO instructions & discussions | 121 | 02-26-2015 10:08 AM |
Possible Problem with Metra Install (door locks) | JohnForeman | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 8 | 11-30-2012 11:53 PM |
DIY : Install catback on 2010 Camaro SS | Nine Ball | Camaro DIY & HOW-TO instructions & discussions | 3 | 08-09-2009 04:36 PM |
