![]() ![]() Drives: Fast Join Date: Mar 2011
Eagle Eyes and Fogs Installed
First off, bumper cover's a PITA by yourself. I suggest taping all the fender edges up so you won't scratch the paint. I wired the Eagle Eye halo's and Fogs up to separate switches so I could have them on independently of one another. I know blah blah blah been done a thousand times. Just for the average Joe, this can be done in your garage in an afternoon. The fogs are from Autozone, fit perfectly just had to dremel out the oem housing. Turned out good IMHO
![]() ![]() ![]() ![]() Drives: '14 SIM 2LT/RS Vert Join Date: Aug 2010
Looks good!
:chevy:
Drives: 2LT/RS Join Date: Jun 2008
more pics or it didnt happen
CAMARO
Consult your doctor before taking Camaro Side effects include Sudden increase in Heart Rate, Insomnia and occasional hallucinations If you experience Permagrin exceeding 4 hours after taking Camaro, seek immediate Camaro5 Help CAMARO Bringing excitment back into the Garage |
![]() Drives: '11 SS M6, '14 SS 1LE, '17 SS 1LE Join Date: Apr 2011
"The fogs are from Autozone, fit perfectly just had to dremel out the oem housing."
LMAO Good thing they fit, or you would have had to do ??? !!!
Anyone can drive fast in a straight line, its what you can do thru the curves that matters!
'11 CGM SS M6 ordered in 3/11, '14 BRM SS 1LE from stock in 10/13 & '17 HBM SS 1LE in 11/16 - all from BeckyD!! |
![]() ![]() ![]() ![]() Drives: 2013 Hot Wheels Special Edition Join Date: May 2009
Looks good man, nice job and well done
#6 | |
![]() Drives: 2010 Black 1SS Join Date: Aug 2009
2010 Black 1SS LS3 M6
Power: Kook's 1 7/8" Long Tubes and 3" Exhaust, Injen Full Length CAI, Jannetty Tune Drivetrain: MGW Short Shifter, Street Slayer Twin Clutch, DSS 1 Piece Aluminum Driveshaft, DSS 1000HP Axles, BMR Pro and Delrin Diff Bushings Suspension: BMR Trailing Arms and Bushings, FE6 Swaybar Conversion With Pedders 27mm Front and 32mm Rear ZL1 Swaybars and Links Chassis: Hotchkis Chassis Max Brace, BMR Pro Cradle Bushings Exterior:: Shine by Adam's. ...and plenty more |
#7 |
#8 |
Rocker switches look very nice. Where did you find those?
#9 |
#10 |
I agree, very nice job with the switches - I wouldn't have thought to use that area to install 'em.
#11 |
![]() ![]() Drives: 2010 Camaro LS, 1973 Corvette Join Date: Dec 2010
What fogs did you get from AutoZone? I'm looking for a cheaper alternative than the $200+ factory fogs. Also, can you take a few more pics so I can check them out? I really like the switch placement as well. Looks clean!
#12 |
![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro LS M6 Inferno Orange Join Date: May 2010
Fog lights for 2007-2011 Tahoes are the same part number as the Camaro fogs. You can find the Tahoe ones a lot cheaper as most sellers do not realize they are the same as the Camaro ones.
Gordy
Injen CAI / Solo Mach-X LLT / Solo High-flow res-cats / Barton short shifter / RX Catch Can / RPI Gills / 35% tint / LED Footwell Lighting Front & Rear / Pedders Street 1 / Pedders steering rack bushing / SS struts / Pfadt drop springs / VMax Ported Throttle Body / Spohn Toe Rods / Spohn Trailing Arms / Trifecta Tune / MACE 25mm Intake Spacers Find me on Facebook: http://www.facebook.com/gahammerle |
#13 |
Thanks a ton!!
#14 |
http://cgi.ebay.com/ebaymotors/07-11...Q5fAccessories
So these should fit? Do they fit directly to the open fog housings or do I have to modify them at all?
| DIY: Halo as DRL on Eagle Eyes | MagnumForceGB | Camaro DIY & HOW-TO instructions & discussions | 15 | 03-25-2014 06:54 PM |
| Eagle Eyes and AAC HIDs installed | ga0358 | Camaro Photos | Spyshots | Video | Media Gallery | 10 | 07-21-2011 01:28 PM |
