![]() Drives: 2012 GT500 SVTPP Join Date: Nov 2009
How do you check the power steering fluid?
I have a 2011 SS and I have a strange noise when turning the wheel. I also have some tan fluid on the ground. However I cant figure out on how to check the fluis level. Can anyone help me?
![]() Drives: 2010 Black 2SS/RS Join Date: Jul 2011
well... for starters the power steering is under your engine cover... hope that helps...
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro SS/RS - 2004 Silverado Join Date: Mar 2010
There is a dipstick under the power steering reservoir cap. Simply remove the cap and see where fluid level is at. Note there is a hot and cold level. Check for leaks around the power steering reservoir.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80 2004 Black Silverado 1500 2WD Regular Cab, Short Bed -5.3 LM7, 4L60E, 3.42, G80 2014 White Caprice PPV -6.0 L77, 6L80E, 2.92, G80 |
Ok thanks guys
Hmm...Something Clever
Drives: Blac on Blaq on Blak 2012 Camaro LS Join Date: Dec 2009
What type do u use?
Adjustments: 20% tint all around, Emblem Pros Dash plaque, Rockford Fosgate P-300/12 |
Thread Tools | |
Clutch fluid contamination problems on Vette fixed for Camaro??? | LDGn63 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 11 | 05-28-2012 09:17 PM |
Fluid Leak, Any Advice? | fielderLS3 | General Automotive + Other Cars Discussion | 1 | 06-03-2011 10:32 PM |
Check Your Rear...Fluid | Inspector 17 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 13 | 08-16-2010 01:12 PM |
Bad power steering pump and the police. | Big Brunsy | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 9 | 06-16-2010 09:00 AM |
Voice Your Comments/Suggestions/Input for Focus Group on 2010 Camaro | Mr. Wyndham | 5th Gen Camaro SS LS LT General Discussions | 236 | 04-22-2008 12:43 AM |
