Old 08-08-2011, 10:13 AM   #1
beaSSt 2011
Drives: 2011 SS M6
Oil temperature?
At what temp is your engine oil running at? Stock? Cam? Outside temp?
After installing cam, I noticed the oil temp is running hotter (or maybe I just never paid attention to what it was running before). Currently engine oil temp is around 230-250, although Texas has been hot as f#*% lately. Oil pressure is good, engine coolant temp is ok as well.
G6X3 cam, M6
beaSSt 2011 is offline   Reply With Quote
Old 08-08-2011, 11:26 AM   #2
Pollock
LT4 M6
Pollock's Avatar
Drives: 2018 ZL1 1LE
with it in the upper 90's I am running around 225 or so.
Pollock is offline   Reply With Quote
Old 08-08-2011, 11:51 AM   #3
Blkcamaro757
Drives: 2010 camaro RS SS 6speed
220-240 depending on if im running it hard. With temps outside of 95+
Blkcamaro757 is offline   Reply With Quote
Oil Change Ramp mjlash22 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 17 01-21-2010 10:40 PM
synthetic motor oil? bigd1276 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 71 01-29-2009 12:28 PM
Major U.S. oil source is tapped KILLER74Z28 Off-topic Discussions 32 10-30-2007 09:47 AM
