10-23-2011, 05:09 PM | #1 |
cleaning rubber from burn out in wheel well
I ran the car yesterday at the track and washed it today. I have so much rubber stuck inside my back wheel wells and it would not come off. I ended up using a plastic spackle tool and some Green Wheel Cleaner. After spending about 30 min on each wheel well I still have some on there. What can I use to get the rubber off and what can I put on the well so it will come off easier next time?
10-23-2011, 05:12 PM | #2 |
CamaroFans.com
I use Turtle Tar & Bug remover, but mostly on the quarter panels and not inside the wheel well. It absolutely turns track rubber and VVT to mush... then you have to wipe it away with old rags.
Prior to hitting the track... use the blue painters tape on your paint... much easier to deal with that way... |
10-23-2011, 05:44 PM | #3 |
I have splash guards on so I didn't get much on the quarter panel it was all in the wheel wells. I will pick up some of the Turtle Tar and bug remover and clean them up. I wondering if I put some detail spray or wax on the wheels if that will help?
10-23-2011, 05:55 PM | #4 |
CamaroFans.com
I never got anything on my wheels... but the Armour All wheel protectant will help keep brake dust down. Be sure you have plenty of old rags available with that tar remover... you'll need it...
10-24-2011, 05:37 PM | #5 |
I did some research and came up with a producted called Geddex Burnout Guard. You are suppose to spray the wheel wells and quarter panel with it before you go to the track and then hose it off when you get back home. They say all the burnt rubber will come right off. Sounds like it worth a try!
10-24-2011, 05:39 PM | #6 | |
HMFIC
Drives: 2016 1SS Join Date: Sep 2011
10-24-2011, 05:48 PM | #7 |
Drives: The shiny ones. Join Date: Mar 2010
Pressure washer has always done well for me... at least getting the bulk of the rubber and track prep out of there. The rest of the liner is easily tackled with a long handled brush and a little APC.
I had to do this on all 4 wheels of my buddies 1000+ hp AWD Silverado SS and all the B&T remover in the world wouldn't touch it until I got the pressure washer out and knocked the biggest chunks lose first. |
10-24-2011, 05:51 PM | #8 |
Drives: 2012 2LT 45th convertible Join Date: Jul 2010
Try Adams undercariage cleaner, it keeps mine looking new, feels slightly slick to the touch when clean so perhaps the rubber won't stick so bad next time, I don't run mine on the 1/4 mile but the road track, different situation I know but I think it would be worth a try
Top Ten Reasons I Procrastinate
1. |
10-24-2011, 06:06 PM | #9 |
Adam, I will have to use the pressure washer and then the APC/Brush next time. Ocikat, I never tried the under carriage cleaner but I have a small bottle of it. I will give it a try
10-24-2011, 06:08 PM | #10 |
10-24-2011, 06:18 PM | #11 |
10-24-2011, 08:08 PM | #12 |
I'm interested to see if this works for you also, I know it works really well for daily driving and the ocasional road trak excursion. good product !!
1. |
Similar Threads | ||||
Recommended Tire Sizes for 2010 Camaro | Nine Ball | Wheels and Tires Talk Sponsored by The Tire Rack | 364 | Yesterday 10:58 PM |
Custom Carbon Fiber/Leather Steering Wheel | SS Mike | Local Marketplace | 3 | 02-22-2017 11:17 AM |
3 Piece Wheel Maintenance & Leak Detection | COR Forged | Wheels and Tires Talk Sponsored by The Tire Rack | 8 | 05-26-2013 03:10 PM |
Cleaning the wheel wells.... | BaldCamaroStud | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 11 | 09-19-2011 10:35 PM |
burnt rubber chunks in wheel well | Dentyneice | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 8 | 12-01-2009 06:09 AM |
