12-18-2011, 05:44 AM | #1 |
My First Chevy
Drives: 2011 Camaro 1LT/RS M6 Join Date: Jan 2011
Removing/installing throttle body?
I'll be installing my catch can tomorrow and want to clean off the throttle body. How do I remove and reinstall the throttle body? I hear it's only 4 bolts, so is it really that simple? I'm not that great of a mechanic so I don't want to mess anything up LOL.
12-18-2011, 06:01 AM | #2 | |
having FUN now 13.66@101
Yes it is that easy. 4 bolts. The key is to NOT over tighten the bolts on the re-install. It is only like 89 inch lbs. Not ft. lbs.
12-18-2011, 09:39 AM | #3 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
Look inside the intake manifold snout at the oil caught in the depression just inside the bottom of the snout. That needs to be soaked out with paper towel.
12-18-2011, 10:57 AM | #4 |
Drives: Really Slow Join Date: Apr 2010
There is also a connector that needs to be unplugged.
12-18-2011, 08:55 PM | #5 |
Make sure to push this vvv
IPF supercharger kit, IPF tune, SW LT's, R. Tech HFC's, ARK DT-S catback, SS Brembo brake upgrade, BC Racing adjustable coilovers, Hurst STS, Pfadt rear arm package, Pfadt adjustable sways & end links, Pfadt diff bushings, BMR rear cradle full kit blk bezels,SS diffuser, Innovate gauges.
12-19-2011, 09:38 AM | #6 |
LOL SixJak!!! My wife HAS one of these!!!!
12-19-2011, 09:52 AM | #7 |
The Mark of Excellence
Drives: 2010 ABM 1SS RS LS3 Join Date: Jan 2009
It has an O-ring, not a gasket, the TB will fall off when the bolts come out, so hang on to it and the O-ring. I think the retorque is 89 in lbs.
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein Last edited by PAUL SS; 12-19-2011 at 10:03 AM. |
12-19-2011, 10:43 AM | #8 | |
The V6 is not an O ring, but a steel gasket. True I recommend hanging onto the TB when removing the bolts. And yes, I did post that it is 89 INCH lbs. Be careful when applying the pressure back on those bolts.
Similar Threads | ||||
Cold Air intake, throttle body, headers, lots of questions. | shadowghost21 | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 6 | 10-09-2011 03:59 PM |
95mm Wilson Throttle Body | Jim85IROC | V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment | 0 | 12-29-2009 09:17 AM |
Best method to clean a throttle body on '99 Z | Broshot | 4th Generation Camaros | 5 | 07-19-2009 11:50 PM |
