12-31-2011, 09:27 AM | #1 |
fog fuse?
is there a seperate fuse for fog lights? my left side is fine, right side is out,,it was on when i first install led's..but then it went out...i put in the original bulb but it still wont light?? suggestions//
12-31-2011, 10:31 AM | #2 |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
No there is only one.
12-31-2011, 01:19 PM | #3 |
EMERALD COAST CAMAROS
Drives: None Join Date: Feb 2010
Pete, have you put an ohm meter on the socket to see if you've got power to it. It's time to turn the wheels to the left and peel the wheelwell back.
12-31-2011, 01:25 PM | #4 |
thanks balman. i found the problem, on the original post from some vendors, they say to tap off the passenger marker light brn wire, to drl blue wire, well that is false,,in the semi dark area where harness is, the brn wire is not brn,,,, it is a brn wire with white tracer, the other wire is black...but could be mistaken ( as in my case) for a brn wire. So i thought i would post this here for some who may do this and look for a BRN wire,,its brn/wht hope that helps others.
Similar Threads | ||||
Fog lights | camarogolfguy | 5th Gen Camaro SS LS LT General Discussions | 36 | 12-03-2017 07:42 PM |
To fog light, or not to fog light. | Xanthos | Cosmetics and Lighting Modification Discussions | 6 | 02-07-2013 04:35 PM |
Roto-Fab | Engine Covers - S/C | Fuse Relay Cover | Radiator Cover | Billet Oil Cap+ | AutoAgenda | Exterior Parts & Accessories | 14 | 02-06-2013 08:43 PM |
Roto-fab fuse relay covers with Rally stripe | Roto-fab 1 | Miscellaneous Items | 0 | 06-23-2011 07:20 AM |
Halo Projector Fog Lights for $72 | RandyB | Cosmetics and Lighting Modification Discussions | 11 | 04-11-2010 09:50 PM |
