12-31-2011, 10:06 PM | #1 |
GM Employee
Drives: 2010 Camaro SS/RS Join Date: Aug 2009
what kind of RWHP numbers could i see?
i have Doug Thorley LT's, SNL V.X cam, Tune and GMPP cat back right now and im sitting at 436rwhp, im wanting to add a TVS 2300, what kind of RWHP numbers could i possibly be looking at if i added one?
2010 Camaro SS/RS - Doug Thorley LT's, SNL V.X Cam/Tune, ADM Cold Air Intake, GMPP Exhaust
12-31-2011, 10:47 PM | #2 |
Drives: 2012 ZL1 Join Date: Apr 2010
My current numbers are in my sig. I was at 461 rwhp before the Maggy,but I also had to install 90lb. injectors and Lonnie's double pumper fuel pump. You'll have to do the same if you want to go above 600 rwhp. The dual pump will run you around $800.00 and the injectors will run 400-800 depending on what brand you get. But on the way home I planted the throttle in second,got sideways,smoked the tires,shifted to 3rd,still smoking the tires, then it bit the road and shot off like a bat out of hell.........WORTH EVERY PENNY!!
Magnuson TVS 2300, 16% OD rear pullies(stock 3.8 on front jackshaft), Vector Motorsports 2.5 cam, hardened push rods, titanium retainers, patriot gold double springs, Dynatech 1 7/8 Longtube headers, gutted cats, F.A.S.T. 90lb. injectors, Lonnie's double pumper fuel pump, ZR1 Plugs, Airade cai, HP tuned by East Texas Musclecars. 660 rwhp / 611 rwtq
12-31-2011, 11:03 PM | #3 |
Call ADM Performance and get the ZL1 fuel pump for a lot less - it's good to 650rwhp - perfect for your application.
12-31-2011, 11:10 PM | #4 |
I think Andy said it was good to 650 with a boost a pump....
01-01-2012, 03:07 AM | #5 |
Drives: My wife crazy with my C5 usage. Join Date: Apr 2009
550-600rwhp . If your not going any bigger, call it a day and drive her wheels off.
01-01-2012, 04:25 PM | #6 |
Drives: 2010 Camaro Auto 2SS/RS Join Date: Oct 2008
What he/she said. I'm at 606rwhp right now on a conservative tune for crap california gas with a maggie, cam, full exhaust, od rear cog and adm fuel system. Keep in mind, I have an auto. You'll see about 60+ rwhp more on a stick.
Built by Jannetty Racing
670rwhp/649rwtq...Scariness to be determined. Jannety Racing forged 416. TVS2300 Supercharger w/Maggie Max Stage 2, 3.6 Pulley, Innovators West 8 rib conversion, OD rear Cog belt drive. Jannetty Racing Rough Idle Cam, LS3 Conversion. Jannetty Racing built 6l80e Trans, Jannetty Racing Custom Converter, Built rear diff w/ 3.45 gears, DSS driveshaft and 1400 hp axles. ADM Twin Pump Fuel System, ADM CAI, Dynatech 1 7/8" Coated Headers, Borla "S" Catback. Custom 18" Forgestar F14's, Nitto 305/45-18 DR's |
01-01-2012, 11:58 PM | #7 |
Drives: '09 G8 GXP A6 Join Date: May 2008
Good rule of thumb is 20 rwhp per 1 pound of boost, 10psi = 200rwhp
It's basically a good guide, not gospel, but close.
2014 Silverado 2wd, rcsb, 5.3, Cam, LT's, 3600 Stall, 1/8 - 8.28 (1/4 - 12.91 @ 106, 1.80 60ft, 4700+lbs, 2700da, so far)
1989 Turbo T/A / Mint / All original / 16K miles / FOR SALE |
01-02-2012, 10:23 AM | #8 |
GM Employee
i wanted 500rwhp when i got my cam but i fell a little short but 550-600rwhp would be about where i would stop since i DD my car
01-02-2012, 05:42 PM | #9 |
Numbers are just that... Numbers. 500 rwhp out of a cam will have such driveability issues down low, with a clutch, or so much stall you rap the crap out of it to get it moving, you wouldn't enjoy it. Theses things make so much power so effortlessly, stick to the sound you want, driveability that's tolerable, and the blower with 8-10 psi will be safe and end at 550-600 for you, no problem. Remember that you actually want to drive your car, not have it sit and dread getting it out, cause it drives like a pro-mod. Be satisfied with a car that needs a cage, but doesn't have one. Somewhere someone always has a bigger truck, faster car, louder stereo, blah blah, set a goal and stop. Of course, I can't, the mod bug never stops.
Similar Threads | ||||
Review: 473 rwhp Mike Norris Motorsports cam | ducatisl | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 30 | 10-26-2010 05:12 PM |
New Dyno Numbers - 638 RWHP - 624 RWTQ ( what the HP at the block ) | advfire | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 22 | 09-01-2010 03:35 AM |
Production Stats and information | sherifdude | USA - Southcentral | 0 | 10-31-2009 03:07 PM |
Over 500 RWHP Automatic | MTI Racing | Forced Induction - V8 | 6 | 10-30-2009 10:51 AM |
STS Turbo - Preliminary Dyno Numbers | ZZcamaro | Forced Induction | 9 | 10-15-2009 08:17 PM |
