01-02-2012, 06:58 AM | #1 |
Chillin Like a Villain
Drives: 2013 2SS Blue Ray Metallic Dusk Ed. Join Date: Apr 2011
Stabilitrak Light came on after headers install
so i just installed some longtube headers on my l99 with cat deletes and the service stabilitrack light flashes on the screen the abs,stabiltitrack,competitve mode,traction mode lights are all. also the engine is running really rough but im assuming its bec of the no cats im getting a tune this coming weds but im not quite sure about the stabilitrack thing im guessing it has something to do with the o2 sensors and not having cats?
anyone? thanks Last edited by TRIPWIRE; 01-02-2012 at 07:13 AM. |
01-02-2012, 07:09 AM | #2 |
having FUN now 13.66@101
Try disconnecting the battery for 30 minutes and see if this clears the trouble on the stabiltrak.
01-02-2012, 07:15 AM | #3 |
I actually did try that already and it didnt work
01-02-2012, 06:39 PM | #4 |
2013 ZL1
Drives: 2013 ZL1 m6 Join Date: Oct 2010
Recheck all of your plugs and wires. I have read that they will cause that error if not connected correctly.
01-02-2012, 07:34 PM | #5 |
Drives: 2010 2SS Join Date: Apr 2010
I had the same message after headers were installed along with a DTC P0300 ("engine misfire detected" although it didn't seem like it was missing). I checked the plug wires along with a few other things then eventually installed new plugs. The stabilitrack message and DTC did not show again. The old plugs looked good, no cracks or anything obvious.
I was more concerned with the DTC than the stabilitrack message, but found that a misfire in the engine will disable the stabilitrack since the engine is a part of the system. You might try a scanner to see if you have any misfire codes. |
01-03-2012, 09:23 AM | #6 |
So I read that the problem for most people was fixed by changing the plugs which I'm gonna do today I hope it works.......
01-03-2012, 10:37 AM | #7 |
Drives: Exige, Miata, Ghia Join Date: Jun 2011
check the plug and wires
01-03-2012, 05:10 PM | #8 |
got the new plugs in today the lights came off and it was #7 that was cracked. boy what a difference! it sounds so sick and the car is running really smooth.
01-03-2012, 05:18 PM | #9 |
navyblueburnout
Glad you got it fixed!
Proud member of the Never going back to Moderncamaro.com club!
07-19-2012, 02:44 PM | #10 |
Drives: 2011 Camaro SS Join Date: Jul 2012
First post, apologies if I do something incorrect. I'm having the same problem (serivce stabilitrak and it turns on as soon as the car starts moving forward). LT header install, normal header codes for rear O2' except I'm not getting any misfire codes. My question is, since I'm not getting any misfire codes, can I rule out the plugs/wires? I had to disconnect the steering shaft to get the headers in, so I'm gonna try and focus on that.
Similar Threads | ||||
What Else is needed to Install OBX LT Headers? | oso305 | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 19 | 12-16-2011 06:26 PM |
Service Stabilitrak after LTH Install? | Infern0 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 23 | 07-27-2011 06:34 AM |
Doug Thorley shorty headers install! | topgun1 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 30 | 05-27-2010 11:27 PM |
JBA releases exhausts, headers and midpipes. | Bewenched | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 17 | 09-16-2009 03:04 PM |
Dynatech Supermaxx Headers w/ Cats--1 set left in stock, special install price!! | Torchdvette | V8 Bolt-Ons & Tunes | 0 | 08-29-2009 02:51 PM |
