Old 01-05-2012, 11:50 AM   #1
DesertCamaro
DesertCamaro's Avatar
Drives: Fast
Are plugged tires balance-able?
Are plugged tires balance-able? One of my stock Pirelli's was punctured on the bottom, Discount Tire plugged it and and I went on my way. After, noticed an annoying vibration in the steering wheel at highway speeds. Took it back, and was basically told I had to live with it, plugged tires usually do this.
This tire has less than 4000 miles on it, any thoughts?
DesertCamaro is offline   Reply With Quote
Old 01-05-2012, 11:57 AM   #2
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2011 2SS/RS/A6 cammed-n-whippled
I never heard that before. Did they try re-balancing them?
POWERFREAK is offline   Reply With Quote
Old 01-05-2012, 12:02 PM   #3
DesertCamaro
Drives: Fast
Nope, they plugged it for free.
Old 01-05-2012, 12:20 PM   #4
bkscott
bkscott's Avatar
Drives: 2010 Camaro 2SS/RS
Plugging should have no effect on the balancing of that wheel. I do not however like plugs on performance tires, as it compromises the speed rating.
I would take it to another shop have them dismount and patch the tire from the inside, and rebalance the wheel.
Have you ever got out of your car and noticed a rock caught in the tread. If you hadn't seen it you would not have known it was there.
If that does not cause a vibe, then the plug shouldn't either.
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10.
ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller.
bkscott is offline   Reply With Quote
Old 01-05-2012, 02:07 PM   #5
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
Plugs have zero to do with balancing. Sounds like they just didn't balance it properly. Even that being said, you shouldn't even need to dismount or rebalance a tire just to plug it. That sort of repair is done on a tire while still mounted to the wheel.
Removal and an internal patch are the preferred method of repair, but I've not had a properly installed plug ever fail, either.
Fquick.com/NineBall
Old 01-05-2012, 02:37 PM   #6
DesertCamaro
Drives: Fast
Well I watched them pull it off the rim so maybe they patched from the inside and plugged it? I'll bring it back next week and have it rebalanced. Thanks for the inputs.
Old 01-05-2012, 02:41 PM   #7
CFD
Drives: 2SS/RS L99 BLACK
Taking the tire of the rim and re-mounting it throws the balancing off unless by some chance it was mounted in the exact same position.
CFD is offline   Reply With Quote
Old 01-05-2012, 02:47 PM   #8
DesertCamaro
Drives: Fast
Didn't know that.
Old 01-05-2012, 02:53 PM   #9
ron10
Drives: 2010 2SS IOM L99
if they pulled the tire off the rim,it must be rebalanced.that is common sence.
Thinking of buying a 2LT. How does it handle in the winter? Bonj87 5th Gen Camaro SS LS LT General Discussions 47 09-02-2011 06:35 PM
Drivers Can't Rely on Summer and All-Season Tires, or Electronics for Control on Snow KILLER74Z28 General Automotive + Other Cars Discussion 25 07-22-2011 11:51 AM
Pfadt Race Engineering Balance Sway Bar package PfadtRacing Wheels and Tires Talk Sponsored by The Tire Rack 0 08-17-2009 02:41 PM
18, 19, & 20" replacement tires ... dougmac Wheels and Tires Talk Sponsored by The Tire Rack 3 03-29-2009 06:27 PM
