01-08-2012, 09:19 PM | #1 |
Drives: 2010 2SS Join Date: Oct 2011
Air/Fuel Ratio
I recently installed a blower cam, heads, and whipple. I also installed afr gauge but I really don't know what I should be looking for as far as a safe number....what do you guys recommend?
Texas Speed long tube headers, Texas Speed KAI, Street Scenes lower billet grill, Heritage grill, BMR 1" drop springs, Nitto tires, Texas Speed head/cam kit, Whipple supercharger, Roto-Fab washer bottle relocate, Katech coil relocate kit, GMPerformance valve covers, Weathertech floor liners, Metra dash kit, Pioneer touch screen
01-08-2012, 09:22 PM | #2 |
12.1:1-14:1-1 blowers run best rich....anything higher then 14.1 is scary.
01-08-2012, 09:38 PM | #3 |
NOW CAMMED & SUPERCHARGED
Drives: 2010 Camaro 2SS/RS Black w/ IOM Join Date: Oct 2008
14.1 ? Really? Ive always thought 11.5-12.5
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
01-08-2012, 09:44 PM | #4 |
Drives: 2010 Camaro SS/RS Join Date: Aug 2011
01-08-2012, 10:09 PM | #5 |
Drives: CGM,twin turbo, cam 2010 SS/RS Join Date: Mar 2011
Really depends on the set up and whats best for you car. Id say 12.1 would be ideal. 11:1-11.5:1 is to fat unless your on a dyno.
01-09-2012, 07:56 AM | #6 |
At wide open throttle I have seen it peg on 10... The lowest my gauge goes is 10...should I get the tune checked out?
01-09-2012, 08:20 AM | #7 |
Yes that and your afr gauge. I believe juiced was talking abut 12.1-14.1 was a broad range. for idle to full rpm. Alot of people just run them fat for no reason other than it helps them slep better at night. What did you do for fuel system? Did you have the car tuned if so with what did you tune it with? 10 is wayyy off. There are alot of good tuners in texas or you can do the whole sct remote tune with ted be some good money spent either way.
01-09-2012, 06:05 PM | #8 |
I did have it dyno tuned by tes performance in Lubbock. I wanted Texas Speed to do it but they just moved and have yet to install their dyno. The Whipple kit came with a MSD fuel pump voltage booster along with 60lb injectors. So do you think I am at risk of damaging my motor? Thanks for the help
01-09-2012, 06:10 PM | #9 |
Drives: 16 Camaro SS, 06 C6 Z06, 15 Sierra Join Date: Nov 2009
whipple and maggie cars at base boost levels generally end up around 11.5:1 when leaving my shop, situations do vary, but i never go leaner then 11.5:1 these are nearly 11.0:1 motors , leave a little on the table to keep them alive for a long time
01-09-2012, 06:41 PM | #10 | |
Similar Threads | ||||
AEM DIGITAL GAUGES (BOOST AND AIR/FUEL RATIO) BRAND NEW! | RabanzZ28 | Audio / Visual / Electronics/ Gauges / Nav | 4 | 01-22-2012 09:16 PM |
Air/Fuel Ratio with Whipple SC | zr1gary | Forced Induction - V8 | 10 | 03-27-2011 06:52 PM |
K&N Intake HP Gains and Air/Fuel Ratio? | Droid6 | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 30 | 05-19-2010 12:20 AM |
**HPTuners Special** Free Shipping on Standard or PRO plus LC1 for $129 | Ragin Racin | V8 Bolt-Ons & Tunes | 5 | 04-06-2010 10:56 AM |
Why i think you cant do a Dyno in the same day | 2SSRS@Gen5diy | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 123 | 10-22-2009 07:37 PM |
