01-27-2012, 03:57 PM | #1 |
'12 ZL1 #742
Drives: his wife crazy Join Date: Nov 2011
No lift shift ??
I was curious to know if anybody had any details regarding the "no lift shift." I'm assuming it has to be in PTM mode 5, but does it specifically have to be in drag mode to use it?
01-27-2012, 04:17 PM | #2 |
Drives: Invalid Join Date: Aug 2010
Yeah I def. do NOT understand what no lift shift means. When you push in the clutch it should just rev right?
01-27-2012, 04:23 PM | #3 |
'12 ZL1 #742
From what I gathered, when you push the clutch in with the throttle fully depressed, it will keep the engine from bouncing off the rev limiter like it would if you WOT shift.
01-27-2012, 04:56 PM | #4 |
Drives: 2012 ZL1 - #670 Join Date: Jun 2009
It was available in the Kappa cars with the GM tune. Basically after launch, you just keep it matted while shifting normally at redline.
01-27-2012, 05:18 PM | #5 |
Petro-sexual
You just keep WOT while you push in the clutch and shift gears and le the clutch back out. It's basically a cheat for powershifting without too much worry of spitting gears out of the tranny or rear pumkin. Just be careful not to go the wrong direction... I'm sure it can't prevent mechanical over-rev'ing...
'20 ZL1 Black "Fury" A10, PDR, Exposed CF Extractor Magnuson Magnum DI TVS2650R // RFBG // Soler 103 // TooHighPSI Port Injection // THPSI Billet Lid // FF // Katech Drop-In // PLM Heat Exchanger // ZLE Cradle bushings // BMR Chassis-Suspension Stuff // aFe Bars // Diode Dynamics LEDs // ACS Composites Guards // CF Dash // Aeroforce // tint // other stuffs |
01-27-2012, 05:28 PM | #6 | |
'12 ZL1 #742
01-27-2012, 05:30 PM | #7 | |
I would say yes ...
01-27-2012, 08:53 PM | #8 | |
I used to be Dragoneye...
"Drag Mode" is PTM 5, which can also be used on a road course. |
01-27-2012, 11:44 PM | #9 |
Drives: '12 AGM ZL1 (SOLD); '07 Ducati 1098 Join Date: Oct 2011
All the magazine reviews I have read describe this function while referring to PTM Mode 5 (more specifically LAUNCH CONTROL), so I'm going to say "YES" it's only available when using LAUNCH CONTROL via PTM Mode 5
01-28-2012, 02:47 AM | #10 |
A GM nut-swinger!
Drives: A Car Join Date: May 2009
In the Cobalt SS, no lift shift available at anytime, you just do it. It helps out a lot for a small turbo charged car where you needed to stay in the boost. Just keep your foot planted and shift thru the gears.
I have not seen anything about no-lift shift in GM press release yet: http://media.gm.com/content/media/us...909_camaro_zl1 What about rev matching in the automatic? The G8 had it I thought.
2004 GTO Quicksilver
2009 G8 Liquid Red 2005 CTS-V Black Raven |
01-28-2012, 07:40 AM | #11 |
Sellin Chevy's since '06
yea I had it in my Turbo Cobalt. It was cool because it held the boost in the recirc valve so when you slammed it into the next gear you were in full boost. All the ricers bought blow-off valves for those cars so you'd have to build boost back up after a shift(Turbo Lag). I too have not heard of NLS in the Zl1. Don't think you would need it because blowers don't really have lag in between shifts.
'19 Z06-7Speed and lowered on stock bolts
'02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub40K orig miles. https://youtu.be/h6faSdcvNew TRADED!'17 ATS-V Coupe w/ Carbon Black pkg https://youtu.be/GH_t-R-TJV0 SOLD! '18 ZL1 Mosiac Blk SOLD!'16 SS Sedan-Forgestars/ARH/rotofab TRADED!2014 SS Sedan SOLD! 2013 Blue Ray1SS/1LE 1of20. TRADED! 2012 White 1SS/RS |
01-28-2012, 08:12 AM | #12 |
Drives: 09 Dodge Durango Join Date: Jun 2011
I think its simply power-shifting but with the car actually programmed to do it
01-28-2012, 08:41 AM | #13 |
Drives: 2010 2SS/RS,M6,Black w/CGM Stripes Join Date: Jan 2010
No lift shift been around for ever. Its just a computer program to stop the ignition when you shift. That way you can keep it at full throttle during a shift. They have piggy back systems for the SS that can do the samething. Nothing new here.
Sent from my DROID BIONIC using Tapatalk
3" RDP Motorsports aggressive cat-back exhaust w/ x-pipe, Vararam CAI, Hurst's short throw shifter, Gary's Customs painted bowties, Ofer's HID DRL/Fog Light wiring harness, Kelvin 8K HID DRL bulbs, ZL1 grille. Johnson's window tint film, LSR lowering springs, Metra dash kit with Pioneer In-Dash DVD head unit. |
02-06-2012, 08:29 PM | #14 |
ZL1 #140
Drives: Camaros: 68 SS, 10 2SS/RS, 12 ZL1 Join Date: Mar 2008
So at the risk of sounding stupid, when performing no-lift shifting, do you use the clutch or does the ignition cutout provide enough reduction of load to permit the synchros to mesh? Is it the movement of the shift lever that triggers the ECU or the clutch movement?
I would imagine at least a slight clutch pressure is still needed but maybe not all the way to the floor? |
Similar Threads | ||||
DIY Raptor Dual Stage Shift Light. | ThunderSS | Camaro DIY & HOW-TO instructions & discussions | 47 | 05-27-2019 08:48 AM |
Official Hypertech Programmer Thread | AUS10BMX | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 334 | 03-22-2014 06:45 PM |
Tap Shift Related Questions | JoeKay | 5th Gen Camaro SS LS LT General Discussions | 85 | 08-22-2010 08:19 PM |
M shift with an Automatic... | Nicholas | 5th Gen Camaro SS LS LT General Discussions | 32 | 01-13-2010 08:44 PM |
