02-11-2012, 01:46 PM | #1 |
Drives: 2019 Camaro SS Join Date: Aug 2011
Turn on power cable question (simple question and I need help fast please)
Which wire do i connect for the turn on cable that connects to the amp from the head unit. that connects to line output converter.
Like in http://www.camaro5.com/forums/showthread.php?t=33592 it shows me all the numbers for the wires. Which number is it? Im sorry im confusing here , but hopefully someone can help me here please! Im in the middle of the hooking everything up and ive come to this bump in the road. |
02-11-2012, 02:20 PM | #2 |
I ran mine to a switch on 12V ignition power (the power outlet on the center console to be exact). That way I could turn the amp off when I didnt want the sub on.
CAI intake | OBX LT Headers | Flowmaster AT Exhaust | Trifecta Tune | SS Rear Diff, Axles & Driveshaft Zex 100 Shot Nitrous | Konig Airstrike Wheels | Custom Engine Cover, Fuse Box & Underhood Bowtie Eibach Springs & SS Sway Bars | BMR Strut Brace | Drake Shifter | Vitesse Paddles | 13.26 @ 105.88 mph |
02-11-2012, 04:01 PM | #3 |
how did you connect it?
02-11-2012, 07:01 PM | #4 |
i connected it to the ciagarette lighter the red cable, but my amp isnt turning in why is that? theres definitely power coming from the battery but its not turning on.
02-12-2012, 12:31 AM | #5 |
Olson Kustom Works
Drives: 91 Camaro, LS3, TVS2300, TR6060 Join Date: Dec 2011
theres a white wire coming from the 44 pin radio plug to the stock amp, thats the factory amp turn on. I usually use that. It keeps the amp on through RAP, I think the cig lighter turns off with the key.
02-12-2012, 10:08 AM | #6 |
i HAve a non ba system, does that apply to me!? I still havent found a a turn on wire, so # 44 will work for me?
02-12-2012, 03:09 PM | #7 |
Olson Kustom Works
My bad, only the BA systems have the turn on wire in the radio plug. Ur just gonna have to go with the cig lighter. There are also a few accessory wires in the fuse block under the hood, but that might be too much work.
Similar Threads | ||||
Supercharger / Turbocharger Results (INFO) Thread | radz28 | Forced Induction - V8 | 273 | 08-15-2023 04:44 PM |
A question about the v6's power | mike25 | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 18 | 07-05-2009 09:46 PM |
Question on Power Seats?? | Gameover | 5th Gen Camaro SS LS LT General Discussions | 8 | 05-17-2009 01:59 AM |
Dumb Power Steering Question | Dave McFly | 5th Gen Camaro SS LS LT General Discussions | 18 | 04-11-2009 02:21 PM |
Turn Signal Question | kanys | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 50 | 01-20-2009 04:14 PM |
