Old 02-11-2012, 06:43 PM   #1
bersterman
bersterman's Avatar
Drives: 2012 2SS/RS M6
Edelbrock X-Pipe
I know that it's a discontinued part, but I'm looking for an Edelbrock X-Pipe for my '12 SS LS3. Anybody have one or know where I can get one?
bersterman is offline   Reply With Quote
Old 02-12-2012, 07:29 AM   #2
68RSZ
68RSZ's Avatar
Drives: 68 RSZ & 2010 SS2RS
Hey, just an FYI, I was found a used one on here and had it installed. I was disappointed, not a noticeable difference in any category except maybe WOT.
I also have the LS3.
I took it for granted that the X would be bent the same as the OEM pipe it was replacing. IT ISN'T!! Found that out after cutting the OEM resonator and mid pipe piece out. Therefore the x pipe will/does hang lower than your stock system. Because the X hangs lower your tranny tunnel brace will not bold back on. To use the brace you will need to get spacers and longer bolts.
I would have been better off saving the $$ spent and buying a cat back or axle back system.
Just my opinion.
68RSZ is offline   Reply With Quote
Old 02-12-2012, 07:40 AM   #3
IROCanSS
Drives: 89 IROC 350
I have a full cat back LS3 exhasut in my barn with a magnaflow X welded in inplace of the H pipe, still has resonators and mufflers...
Interested?
Old 02-12-2012, 11:55 AM   #4
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
What's wrong with the Magnaflow True X pipe?
As for the "hitting", most muffler shops weld the pipes in as they're going to sit. Since the Camaro catback is held in place by so few hangars, you have to push the pipes up, then weld. When the tension is taken off, it should fall back in it's original place.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 02-14-2012, 05:05 AM   #5
Mikes SS
Mikes SS's Avatar
Drives: '10 CGM 2SS/RS 6M
I installed mine and it works just fine. Tunnel brace is installed too.
Mikes SS is offline   Reply With Quote
Old 02-15-2012, 05:54 PM   #6
Irnwkrkev
Irnwkrkev's Avatar
Drives: 2011 SS/RS LS3
I've got one installed and had no problems with the tunnel brace (LS3). Perhaps you have it upside down. I think I remember it being a little skewed.
Irnwkrkev is offline   Reply With Quote
Looking for edelbrock x pipe camoman V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 4 12-30-2011 08:49 PM
Edelbrock X Pipe 68RSZ Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 04-14-2011 12:50 PM
Edelbrock "X" Pipe Havnaparty Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 12 03-11-2011 06:51 PM
FS Edelbrock x pipe NIB jimpfromwv V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 7 12-28-2010 08:57 PM
Edelbrock X Pipe Install L99 SS/RS ParisTNDude Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 33 11-06-2010 11:00 AM
