Old 02-21-2012, 08:56 PM   #1
khalsa013
Drives: 2ss & ZL1
Send a message via AIM to khalsa013 Send a message via Yahoo to khalsa013 Send a message via Skype™ to khalsa013
NEED HELP!!!! HURST PROBLEMS!!diy
so i have a 2010 camaro ss with normal m6 shifter, a seller on here is giving me a deal on the fatory hurst shifter from a 2011. it comes with the knob shaft and ring with screws. BUT i heard from the dealer that i need a bracket replacement too? do i, the owner said that he's replaced a handful and never changed the bracket.
so i need help!!! i dont know what to do?
khalsa013 is offline   Reply With Quote
Old 02-22-2012, 11:46 PM   #2
Kenji
Kenji's Avatar
Drives: 2SS/RS M6 SW
While the factory Hurst shift lever will physically fit into a non-Hurst bracket and reduce throw... the shifting will not be as smooth without the Hurst bracket and may even feel somewhat notchy while shifting. The shift lever pushes a linkage rod in and out of the transmission. By not using the Hurst shifter bracket the Hurst shifter lever will not push this rod straight but at an angle into and out of the transmission. Many people will try and cut corners by not installing the bracket (it is a major PITA to replace the whole bracket), but they are also cutting corners in shift quality. The aftermarket Hurst shifter gets around this issue by repositioning the pivot point while maintaining a straight (direct) angle on the transmission change rod.
Kenji is offline   Reply With Quote
Old 02-23-2012, 10:17 AM   #3
nak3dsnake
Drives: 2010 Camaro IBM 2LT/RS M6
Kenjis right, the entire shifter assembly was reworked on the factory Hurst shifter. I've seen one and its very different from the stock, has a revised bottom bracket and a top one on the shifter assembly. It may or may not fit, and even if it does the support it would need from the new brackets wouldn't be there.
nak3dsnake is offline   Reply With Quote
DIY Hurst Short Throw Shifter Install - Pix and Video TAG UR IT Camaro DIY & HOW-TO instructions & discussions 121 02-26-2015 11:08 AM
20x9.0 / 20x11.0 HURST Stunner wheels - Starting @ 1258.00 shipped Speed Depot Wheels / Tires 104 01-29-2013 04:48 PM
Hurst Series 1 Kit for Sale STPofKC Local Marketplace 3 03-24-2012 01:47 PM
Hurst Shifters from GmPartsDirect.com GmPartsDirect.com Transmission / Driveline 0 01-24-2011 05:41 PM
The New and Improved Hurst Shifter alfie43 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 29 08-11-2010 11:47 PM
