Old 02-27-2012, 01:48 PM   #1
AllBlackCamaro1
Drives: 2011 V6 Camaro All Black
Cool illuminated rear LED bowtie
im trying to decide on purchasing the led rear bowtie and im wondering whats the pros and cons on getting them dual intensity circuit?... if anyone can help me out ill appreciate it thanks. (i want them bright and on the whole time my car is on)..
AllBlackCamaro1 is offline   Reply With Quote
Old 02-27-2012, 01:59 PM   #2
ORACLE Lighting
ORACLE Lighting's Avatar
Drives: @oraclelights
Then you want the bowtie to be a running light so do not order the DIC
ORACLE LIGHTING
www.ORACLELIGHTS.com
1(800)407-5776
ORACLE Lighting Camaro Products [CLICK HERE]
ORACLE Lighting is offline   Reply With Quote
Old 02-27-2012, 03:00 PM   #3
AllBlackCamaro1
ok thank you
Old 02-27-2012, 03:04 PM   #4
atver22
atver22's Avatar
Drives: 2011 2SS/RS Synergy Green
aac correct me if i am wrong but the DIC would give you the ability to hook it up like the brake lights right? One brightness all the time then brighter when you step on the brake.
atver22 is offline   Reply With Quote
Old 02-27-2012, 03:10 PM   #5
ORACLE Lighting
You got it
ORACLE LIGHTING
1(800)407-5776
Old 02-27-2012, 03:13 PM   #6
Saint Alban
Saint Alban's Avatar
Drives: '14 Black 2SS RS
I have the DIC and I say, for an extra $10, get it. While your car is running, it will be on and match the brightness of your running lights. Then, when you hit the brakes, it'll brighten and match the brightness of the brake lights. Why not? Honestly, DIC or not, I don't know of any cons.
Saint Alban is offline   Reply With Quote
Old 02-27-2012, 03:29 PM   #7
FL1CK
Switchin' n Twitchin'
FL1CK's Avatar
Drives: 2011 Camaro
I'm just curious as to why you put when you started the thread with that post? (Usually, that's used for someone posting something that didn't read the thread and it's already stated.)
On a side note, I'd get the dual intensity for brighter when I applied my brakes as stated above.
I am not childish, you're just being a poopy head!
FL1CK is offline   Reply With Quote
Old 02-27-2012, 03:31 PM   #8
mattbaer
Drives: 2010 Camaro SS
I got the DIC. I did not like the look so I ended up hooking up both to the running lights.
when I had it hooked to the running and brake lights, when the brakes applied it looked good but when the brake were not applied the bow tie looked 1/2 lit.
mattbaer is offline   Reply With Quote
Old 02-27-2012, 06:31 PM   #9
Saint Alban
That's weird. This is just running, no break. This probably 6 months ago when I got it. It never looked half lit to me.
And now with my afterburners.
Old 02-28-2012, 09:37 AM   #10
mattbaer
Mine did not look like that unless brakes were on or both sides where hooked up. The top left was out or the bottom left would be out if hooked up to running and brakes. Once the brakes were lit the whole bow would be lit.
Old 02-28-2012, 09:41 AM   #11
thespymaster
thespymaster's Avatar
I went with DIC option as well..........
2014 C7 Stingray 3LT/Z51
2013 Camaro SS
2012 Camaro ZL1 - 850 HP
2015 GMC Denali 3500HD 4x4
2012 GMC Sierra 3500HD 4x4
Old 02-28-2012, 12:18 PM   #12
Saint Alban
Something was definitely wrong with yours. Running or braking, none of the LEDs turn off. They only get brighter.
Old 02-28-2012, 12:31 PM   #13
ORACLE Lighting
Not necessarily, we had several custom orders like that
ORACLE LIGHTING
1(800)407-5776
Old 02-28-2012, 03:29 PM   #14
Saint Alban
Of course, but I meant if all he ordered was the normal bow tie with dual intensity, it shouldn't have done what he's describing.
AACstyle LED Illuminated Rear Bowtie>>> First Pics! ORACLE Lighting Cosmetics and Lighting Modification Discussions 359 03-13-2015 03:09 PM
In Search of LED Rear Bowtie Install Step by Step Instructions SynerJersey110 Camaro DIY & HOW-TO instructions & discussions 21 05-29-2014 11:44 AM
How to remove gold center from rear bowtie SSyanide Cosmetics and Lighting Modification Discussions 20 03-12-2012 08:33 PM
LED Rear Bowtie? jtmaro Cosmetics and Lighting Modification Discussions 15 02-26-2011 06:43 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
