03-04-2012, 03:17 PM | #1 |
Drives: SGM, 2011 2SS/RS, L99 Join Date: Oct 2011
Squeaking after header installation.
My car squeaks during hard right turns since I had my headers installed. I put it on a lift today and tightened down all the clamps which were a little loose but still squeaks. The guy who installed my headers and from what I've read on here is that you only want to tighten the headers on to around 15lbs of torque. I'm sure the squeaking isn't normal but I have only started hearing it since about 5 days after the installation. Maybe the headers aren't on tight enough.
Any ideas will be greatly appreciated, I'd hate to be driving down the road if something goes wrong. Thanks.
K&N air intake, Solo w/Jpipes axleback, SP 1 7/8 LT headers
03-04-2012, 03:20 PM | #2 |
is it hitting a heat shield or anything?
03-04-2012, 03:30 PM | #3 |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
Headers size (1 7/8" or 2") and brand?
If it happening on right turns it sounds like the header is rubbing up against something when there's a transfer of weight. There should be no squeaking. I would climb under the car with a flash light and look for places where the header is really close to the frame, bolts, etc. It doesn't have to be touching at rest to rub going around a turn. I've seen this on GTOs (headers rubbing on right turns - from contact with frame bolts). I'm not saying this is your issue, but its something to look at. |
03-04-2012, 03:37 PM | #4 |
No, well not that I know of and I checked everything to make sure there was no rubbing. I just thought maybe the bottom weight of the LT's swayed during the hard turns causing the squeak. It makes me think its the passenger side header since it only squeaks on right turns. I had an oil change with a 24point inspection a couple weeks before that done by the dealership but thats been the only maintenance done.
03-04-2012, 03:43 PM | #5 | |
06-08-2013, 06:59 AM | #6 |
Drives: 2013 Camaro SS Join Date: Feb 2011
I just installed my stainless power headers last night and the drivers side is rubbing on the steering shaft on hard right turns. It sounds like you might be having the same problem as me. I am going to call SW today to see how they are going fix this issue.
06-08-2013, 07:07 AM | #7 | |
MY SS is SOLD
Drives: AGM 2012 Camaro 2SS/RS L99 Join Date: Mar 2012
CAI, Dynatech Headers, HF Cats, JRE Tuned, Corsa Cat Back, Strut Tower Brace.
06-08-2013, 07:46 AM | #8 | |
Drives: 2011camaro SS Join Date: Nov 2012
Sounds like something else? |
06-08-2013, 09:48 AM | #9 |
Drives: 2011 IBM Camaro 2SS/RS Join Date: Sep 2009
It's from rubbing your steering column. My Doug Thorleys do this too...hope you have better luck than I did. I called and had them send out another set that was supposed to fit but it rubbed in the exact same spot. Just for reference, I have 1 7/8" headers too. Very annoying and makes me mad because the steering column has a ring around it from it rubbing.
06-08-2013, 10:28 AM | #10 |
chevy pride
did u torque everything down to specs. check tunnel brace
check out ky speeds fb page https://www.facebook.com/kyspeed |
06-08-2013, 10:28 AM | #11 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
^^im with him
06-08-2013, 10:42 AM | #12 |
Drives: 2011 Camaro 1SS Join Date: Dec 2011
you guys put ur braces back on? ... fml
06-08-2013, 10:50 AM | #13 |
V8 Lounge member #2
Nope left that crap out, didn't fit with my chokemaster 3" exhaust. It's useless anyways lol
Thread Tools | |
Similar Threads | ||||
Question About LT Header Installation | Powhusku | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 22 | 01-19-2012 09:40 AM |
Header Installation | dpslugger12 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 6 | 12-21-2011 10:51 AM |
header best price, installation | mdub76 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 5 | 10-18-2011 05:48 PM |
AR Header Sale!!! | Ragin Racin | V8 Bolt-Ons & Tunes | 15 | 06-27-2011 04:11 PM |
Header installation in Michigan | jam75green | USA - Great Lakes | 3 | 09-27-2010 04:21 PM |
